    Looking for two ruby scripts
    6 Posts 2 Posters 538 Views 2 Watching
    • P
      patricprz
      I have been searching google and this forum but no luck.
      1. I am looking for a ruby script that cuts a large model (building) along the section and splits it into two halfs, so that I can delete one half and render the rest - if possible filling in the walls.
      2. I am looking for a ruby script that arrays and rotates an object incrementally for example every 1m it rotates by 1 degree.
      Anyone help is very much appreciated
      P
      • TIGT
        1. Whaat's 'Zorro2'
        2. Chris Fullmer's 'ComponentStringer'
        • P
          patricprz
          @tig said:
          1. Whaat's 'Zorro2'
          You Sir are a Star. β˜€
          • P
            patricprz
            Sorry - I do not think Component Stringer is the correct script.
            Have a look at these images:
            https://lh4.googleusercontent.com/-3nilhrldYko/Tn8cR_fRNyI/AAAAAAAACNc/rjwuhW7etkk/s912/Rot%252520Mul%2525202.jpg
            https://lh5.googleusercontent.com/-QyBZ_k3Wz7k/Tn8cOAGReiI/AAAAAAAACNY/al0yxUDKq2g/s800/Rot%252520Mul%2525203.jpg
            The mullion (vertical fin) is rotated by 1 degree every 900mm 65 times. I had to do this manually but there must be a ruby out there that can do this... I hope πŸ˜’
            Let me know and thanks in advance
            • P
              patricprz
              Oops - I think the you tube video I watched was not on the same ruby. All under control (for now πŸ‘ )
              • TIGT
                To do what you want my 'Grow' tool will copy a selected component and rotate it about an axis... this is in X-axis only = 10nr @2m c/c @5degrees [for clarity] but your requirements would work too Capture.PNG see here http://forums.sketchucation.com/viewtopic.php?p=324331#p324331
