    [req]biggest segment of a selection
    8 Posts 2 Posters 752 Views 2 Watching
      Don't remember if this yet existing 😳
      Biggest or smallest segment of a selection of segments
      0.001 precision
      Connex problem : the biggest distance between two curves ?
      0.001 precision
      Even without precision will be yet fine πŸ˜„
      Thx by advance
        This one-liner copy+paste + <enter> in the Ruby Console highlights the longest segment in the selection and prints its length/id
        d=0;s=Sketchup.active_model.selection;a=s.to_a;q=nil;a.each{|e|(q=e;d=e.length) if e.class==Sketchup;;Edge and e.length>d};s.clear;s.add(q);puts d;q
        To return the greatest distance between two curves how do you mean to measure it - clearly its the distance between opposite ends! Or do you mean between matching vertices ?
          Many thx! Works like a charm! 😎
          For the other thing
          yes πŸ˜‰
          Maybe this can help you β˜€
          But seems to me that your script gives the good answer as soons as segmemts are drawn between the 2 curves
          [flash=560,315:3421aels]http://www.youtube.com/v/m6Qww5j3C6g[/flash:3421aels]
            I you have 2 similar biggest segments seems the first created is selected πŸ˜‰
              Yes ?
              If you want the last change
              e.length>d
              to
              e.length>=d
              It you want an array of all edges of the max length it'd be relatively simple...
              After getting the max-length revisit the edges and compile an array of all edges with that length. Then add that array to the selection instead...
                Thx I can easily change for have the last πŸ˜„
                That is an another story for the array or for the smallest! 😳
                  This version returns the longest edge [if there are two equal the last one added is used]
                  d=0;s=Sketchup.active_model.selection;a=s.to_a;q=nil;a.each{|e|(q=e;d=e.length) if e.class==Sketchup;;Edge and e.length>=d};s.clear;s.add(q);puts d;q
                  This one finds the shortest edge
                  d=0;s=Sketchup.active_model.selection;a=s.to_a;q=nil;a.each{|e|d=e.length if e.class==Sketchup;;Edge and e.length>d};a.each{|e|(q=e;d=e.length) if e.class==Sketchup;;Edge and e.length<=d};s.clear;s.add(q);puts d;q
                  This version makes an array of all edges with the maximum length
                  d=0;s=Sketchup.active_model.selection;a=s.to_a;q=[];a.each{|e|d=e.length if e.class==Sketchup;;Edge and e.length>d};a.each{|e|q<<e if e.class==Sketchup;;Edge and e.length==d};s.clear;s.add(q);puts d;q
                  This version makes an array of all edges with the minimum length
                  d=0;s=Sketchup.active_model.selection;a=s.to_a;q=[];a.each{|e|d=e.length if e.class==Sketchup;;Edge and e.length>d};a.each{|e|d=e.length if e.class==Sketchup;;Edge and e.length<=d};a.each{|e|q<<e if e.class==Sketchup;;Edge and e.length==d};s.clear;s.add(q);puts d;q
                    You rock as allways! πŸ‘
                    Thanks again! 😎
