[Plugin] Audible Tool Click (Oct 2, 2011)
I wanted an audible hint when changing a tool in SketchUp, so here's a quickie.
You will likely need to change the path to another sound file of your choice.
Update Oct 2, 2011
- Added AppObserver to re-activate the click after New Model/Open Model.
You might consider adding 'filtering' to the tool changes, otherwise doing 'transparent operations' like orbit/pan/zoom will also 'beep' annoyingly...
Register LoginAdvertisement
