    Tips about running more than one Sketchup
    23 Posts 10 Posters 9.9k Views 10 Watching
    • dukejazzD Offline
      dukejazz
      😎 5 tips about running more than one sketchup
      Tip 1) Run and do more with sketchup
      You can run more than one sketchup programs at the same time.
      Just hit your shortcut key twice and find out.
      Tip 2) Cut and paste or paste in place
      a) You can cut and past between between same levels of sketchup programs. 8-8 7-7 6-6
      b) There are some copy programs that can copy many levels of copys with sketchup (25 level+ or more) M8 Free Multi Clipboard: Free Clip, Spartan Trial Upgrade
      Tip 3) Use each sketchup for different task
      Use one for laying out and other for creating the object.
      Tip 4) Toolbars behavior
      a) Remembers the last program exited is how the toolbars will look when you restart.
      b) Common view can be saved by saving view - toolbar - saving toolbar positions.
      Tip 5) Can use more plug-ins folders
      a) By copying sketckup 8 to another location, you can load more plugins.
      b) Also a empty plug-in folder is a great viewer
      c) For zone testing for new downloaded plug-ins
      (hint)
      a) When copy is completed, make a new shortcut (sketchup2) to new sketchup.exe.
      b) Load new plugins with a ruby toolbar.
      c) Clean your registers, when needed.
      All of this will help to over come the overloading of gray outs and bug splat.
      (6 tips) for a better sketchup 8 m2...........pg 2
      I made a plugin to make you life easier to control another sketchup
      my tips that I posted here as help me to write this plugin.
      History of the plugin
      [plugin] Another_Sketchup v1.0 Dec 28 2011
      [plugin] Another_Sketchup v1.1 Jan 18 2012
      [plugin] Another_Sketchup plus v1.2 Jan 31 2012
      [plugin] Another_Sketchup plus v1.2.1 feb 2 2012
      (14 tips ) Sketchup noted Hints: by dukejazz in the making of Another Sketchup Plus ...........pg 2
      • dukejazzD Offline
        dukejazz
        If you Know more please add to your tips here?
          tfdesign
          Hate to start yet another Mac vs PC war, but on a Mac, you're rid of this little curse, as you can have as many windows open at the same time in SU! By pressing the "Command" and "`" keys sequentially, you can scroll through your open windows within the current selected application.
          Very useful! πŸ˜„
          My book "Let's SketchUp!" Download from here
            Jim
            I think you misspelled "Love" πŸ˜†
            Interesting idea of opening 2 SketchUp instances each with a different set of Plugins.
            Related: There are couple (one free, one not) of Plugins that open a Component in a new SketchUp window for editing, then reload them in the original model:
            1. 404 Not Found
              (forums.sketchucation.com)
            2. Website Unavailable
              (www.suplugins.com)
            • Chris FullmerC Offline
              I'm still confused who can't open more than one window of SketchUp in Windows? I have 4 open right now. 3 from SU 8 and one from Su 7. I've had more open in the past. Its a non-issue for me. Am I doing something wrong?
              All my Plugins I've written
              • BoxB Offline
                To roughly quote Gaieus from when I was confused about that,
                Those are multiple instances of SU running. In the Mac, you can open multiple files in the same instance.
                  tfdesign
                  Yes, you're quite right Jim! 😳 I'll rephrase that....
                  I don't want to start another blah blah war but.....blah blah blah........!
                  πŸ˜†
                  It is a right pita about not being able to open multiple windows of SketchUp in Windows. Perhaps Google should introduce tabs for Windows users? (I also use, (and love) Windows 7!)
                  edit; Sorry, yes Chris is right. I swallow humble pie! 😳 'Multiple windows' I meant to say. You can open multiple instances. It's just, from what I remember a little clunky- having all those SU icons in the dock. πŸ˜•
                    tfdesign
                    Yes, I just corrected myself. πŸ˜„ 😳
                      Aerilius
                      About multiple versions of SketchUp:
                      As to what I tested, SketchUp sometimes loads the installation from the default directory even when you have double-clicked on the exe in another (copied) directory (the same main version number). I believe it remembers the location from the registry. πŸ˜’
                      When you install another language version (I do that regularly for the help forums), SketchUp checks if its language is the same as the OS language; if not it falls back to English (for example French SU on German WinXP shows up in English). That can be quite annoying since Windows licenses are mostly for one single language.
                      A personal work-around is that I use Wine (when I'm not on XP), a software that pretends towards Windows programs being run on a real Windows. There I can run different SketchUp versions without knowing of each other and in different language setups.
                      • broomstickB Offline
                        broomstick
                        My tip would be: different versions save your life!
                        Keeping Sketchup 7 free at hand means you can import dwg files, and then open everything in Sketchup 8 free to do all the work!
                        πŸ˜‰
                        • jeff hammondJ Offline
                          jeff hammond
                          @dukejazz said:
                          Tip 2) Cut and past
                          my tip (or is this already obvious? πŸ˜„ )
                          use 'paste in place' instead of just 'paste'.. not only do you use the clipboard to easily bring geometry in&out of multiple windows, you use paste in place in order to put geometry in the exact same spot within the drawing area.
                          it's located in the file menu but should definitely be assigned to a keystroke.. i use β‡§βŒ˜V
                          dotdotdot
                            i use β‡§βŒ˜V
                            Is that Greek for Shift+Ctrl+V? πŸ˜† (that's what I use actually)
                              jeff hammond
                              @gaieus said:
                              i use β‡§βŒ˜V
                              yes, i do in fact have a greek keyboard! how'd you know?
                              πŸ˜†
                              dotdotdot
                                Well, I did not really mean "Greek" but just the saying when something is "Greek to me". We (in Hungary) actually say "it's Chinese to me" but these proverbs have different variations.
                                "A hungry horse dreams of oats" would sound like "a hungry pig dreams of acorns" in Hungarian (well, would not really soundlike this as I translated it...)
                                  jeff hammond
                                  nah.. i know that saying too (and i also use the chinese version more often than the greek)..
                                  i was just making a joke out of it..
                                  dotdotdot
                                    Ah, one never knows... πŸ˜†
                                    • irwanwrI Offline
                                      irwanwr
                                      πŸ˜‰
                                      πŸ‘
                                      that is interesting. i think i need to search for SketchUp 7 to download.
                                      • dukejazzD Offline
                                        dukejazz
                                        [plugin] Another_Sketchup 1.0
                                        Works in Sketchup 6,7,or 8
                                        It works in the context menu named " - Another Sketchup ".
                                        Just give a right click on any object for automation of loading a another sketchup.
                                        Its helps to rework any docucments objects.
                                        When done reworking then paste in place back to your docucment.
                                        It have the following submenus: - note
                                        1 Copy selected to another Sketchup. -rework object
                                        2 Move selected to another Sketchup. -rework object
                                        3 Paste in place to another sketchup. -rework object
                                        4 Copy all to another sketchup. -restart unhidden plugins
                                        5 Copy all and Exit your Sketchup. - Please place in place back after it closes to any of the open sketchup or start a skp file to auto paste in place. If it paste in place to your new sketchup and you dont need it just hit undo. Warning the copy is lost if you clip to clipboard before you paste in place.
                                        [plugin] Another_Sketchup_Plus v1.2 is now a toolbar
                                        • dukejazzD Offline
                                          dukejazz
                                          Lower plugin memory usage, mean bigger skp graph files. Yes?
                                          • dukejazzD Offline
                                            dukejazz
                                            Your guys are right!
                                            My tips 2 should read
                                            Spartan can store, name, and save hundreds of small pasteable objects
                                            • 1 / 2
