    [Plugin] Bolt Maker (Final Update 7-Feb-2012)
    101 Posts 31 Posters 98.0k Views 31 Watching
    • bmikeB
      bmike
      very nice...
      just tested it and it will come in handy for my timber to steel connections.
      i did notice that if bolt 2 components together, it will update all components in the model with the holes, regardless of if those components were part of the bolt assembly. small niggle, and something i can work around, for sure.
      nice work!
      mike beganyi design + consulting llc
      • sdmitchS
        sdmitch
        Of course that's the nature of components. Editing one changes all. Before using Bolt Maker, right click on each and choose "Make Unique". Groups don't have that problem.
        http://sdmitch.blogspot.com/
        • EscapeArtistE
          EscapeArtist
          Very nice plugin. Thank you!
          • K
            ksor
            @sdmitch said:
            OOPS!!!! Sorry Bolt Maker fans. Dispite what I thought was adaquate testing, I found a problem while playing around with the plugin this morning. It has been corrected and a new copy posted.
            Hi younger brother !
            You say it's the file is updated but where is the updated file placed ?
            Best regards
            KSor, Denmark
            Skype: keldsor
            • TIGT
              Most logical authors put the current file download-link on the first post in the tool's thread.
              So look there.
              It's quite easy to add a link to that very page in the post announcing the update - see most of my scripts' threads...
              • K
                ksor
                So look there.
                I allready HAVE that file - so it's OK !
                But normaly you can't place a new posting as the first posting i a thread - right ?
                You have to EDIT the first post
                Best regards
                KSor, Denmark
                Skype: keldsor
                • TIGT
                  Correct - the author owns the first post [usually where the first download link as given]... so he can edit that post later if the script is updated.
                  So if the file changes he updates the script on the first page and the thread's title to suit.
                  The Plugins Index 'sniffer-dog' spots titles starting with [Plugin] and also notices any changes to them for version/date etc so the index is auto-updated...
                  • guanjinG
                    guanjin
                    @bmike said:
                    very nice...
                    nice work!
                    Too strong
                    I come from China, is to learn
                    • guanjinG
                      guanjin
                      First select line prompt
                      Edge does not belong to the selected Surface
                      Too strong
                      • guanjinG
                        guanjin
                        • sdmitchS
                          sdmitch
                          If you would care to attach the model to your post, I will try to determine what the problem is.
                          If an inference has been established to an edge on another face, that can confuse things and cause this error because the inferenced point is what you get and not the point you think you are pointing at.
                          • guanjinG
                            guanjin
                            Thank you:sdmitch
                            无标题.skp
                            • sdmitchS
                              sdmitch
                              juanjin,
                              I didn't have any problem with your model. It has to be a odd coincidence that you were getting the error message. Although it is not required that all entities be components or groups, I would highly recommend it so that the plugin can better identify the selected face.
                              • guanjinG
                                guanjin
                                @sdmitch said:
                                juanjin,
                                Thank you:
                                sdmitch
                                But does not affect the use, multi-select time
                                • J
                                  jumpjack
                                  This plugin looks interesting, but my english is poor and terms used to describe how a bolt is built are hard to understand...
                                  An animated GIF like above one, but showing how to PROPERLY use the plugin, inserted into first post, would be very good.
                                  Additionally, I read in first posts about reversed faces in the bolt: I don't know if this bug has been fixed as it is not important in virtual world... but 3 years after creation of this plugin we have now 3d printers, which complain about inverted faces! A bolt with inverted faces cannot be printed, because it appears as a hole not surrounded by any material (i.e., impossible object).
                                  • sdmitchS
                                    sdmitch
                                    Have you viewed the tutorial on my blog?
                                    • bmikeB
                                      bmike
                                      agreed.
                                      wonder if there is code that can make only the components selected when running the plugin unique, or have them downgrade to groups...
                                      but, nice work.
                                      • D
                                        dammerel
                                        Great plugin but how easy would it be to include an option to add a washer under the nut ?
                                        Andrew
                                        • sdmitchS
                                          sdmitch
                                          Andrew
                                          • J
                                            jumpjack
                                            Is this plugin supposed to create 3d-printable bolts? I only get plain cylinders with DRAWN threads!
                                            And, by the way, reversed faces prevent a model from being printable.
                                            • 6
                                            • 4 / 6
