    [Plugin] Bolt Maker (Final Update 7-Feb-2012)
    101 Posts 31 Posters 98.0k Views 31 Watching
    • N
      Niffler
      @sdmitch said:
      Neffler and all, Why plugin Bolt Maker tends to be flaky is as much a mystery to me as you. I can assure you that Vista is not the problem since I developed Bolt Maker on a Vista system. As to size of bolts, I have made them from 1mm to 5" diameter without a problem. There is nothing "hidden" in the plugin that prohibits any version from running regardless of how many you have installed.
      Greetings Sdmitch,
      "Oh happy days, oh happy days" ☀ The sun is shinning! I downloaded your latest Boltmaker plugin into my Vista system, fired-up Sketchup, clicked-on Boltmaker and it works!! I even tried a five-inch, monster bolt and that worked.
      Now, for the bad news. 😕
      Sorry for raining down on your parade, mate. When boltmaker first opened, I was greeted with the error message:
      "Error occurred when reading bolt_data file." 👿
      Sorry!
      • sdmitchS
        sdmitch
        neffler, The error message you mentioned is one of the things I added to the latest version. I found that while testing and changing units from inches to millimeters and back again that it caused an error on one occasion when reading the defaults from the previous run. My guess is that this read error is what was causing the plugin to not run for you previously since I had not coded for this posibility. After dismissing the message, the plugin should run normally. I added this message just so you would know that and help explain why the defaults presented might not be what you expected or last entered.
        http://sdmitch.blogspot.com/
        • J
          Jim
          Wow, Sam - I just checked out your blog and you have quite a collection of plugins going on there!
          • utilerU
            utiler
            You're not wrong, Jim!!! nice collection, Sam!
            Just Curious...
            • A
              AlainBo
              Hi sdmitch,
              Is it possible to expect other kind of head such as Phillips, Torx, countersunk?
              Another thing could be to give an entry field for length as screws normally match to standard lentgh. I suppose it would be very difficult to embed lengths table....
              Regards,
              Alain
              • sdmitchS
                sdmitch
                Hi sdmitch,
                Regards,
                Alain
                As the name implies, Bolt Maker makes bolts not screws. I'll leave that one for someone else.
                • kenK
                  ken
                  Great Plugin. Would it be possible to keep the tool active with the setting so one could install a line of bolts at numerous construction points, instead of having to make the selection again and again. So if I had 5 areas that I wanted this type of bolt, and these areas had the same requirements, I could after making the first bolt, just select the next 4 construction points and make the same bolt at all the construction points.
                  Thank you for this plugin
                  Ken
                  • sdmitchS
                    sdmitch
                    Ken, That seems like a reasonable feature. I'll investigate the possibilities.
                    • sdmitchS
                      sdmitch
                      Bolt Maker X offers an additional bolt location option for situations where non-rectangular components/groups are envolved and a repeat option to allow the placement of bolts of the same specification.
                      • R
                        raineysky
                        Thank You Sam
                        • M
                          Michaelv
                          Awesome! Here is some Mac testing.
                          Couple little things, see picture:
                          When the bolt length is across a profile, it adds a big length of thread. Whether I use location or offset.
                          If I use offset with the cylinder it doesn't work too well, but you know that and it is why we can now use absolute location and that works great.
                          In the mac option box, the size is very small when implemented like that, so the option "Locate by offset" yes/no becomes "Locate by" yes/no, I suggest "location" Offset/Pick (see PM)
                          • sdmitchS
                            sdmitch
                            The problem with the "thread" is the shape of the bottom group. The bolt has to go in and out of the group twice and does not find the faces in a top down order thus causing the problem. I am aware of the problem and I'm working on it.
                            • M
                              Michaelv
                              OK thanks
                              • sdmitchS
                                sdmitch
                                To all Bolt Maker users: Bolt Maker XII - The final edition has been posted. It corrects the problem with multiple entry and exit point on any given group or component. It even allows and handles non-parallel faces. A fixed length option has been added so that bolts that do not require a nut can be placed. Check out the updated tutorial for further clarification.
                                https://docs.google.com/open?id=0Bw8zdmaKDWIfZDdkNWM5OGEtMDZiMC00NTYxLTkyODMtY2NkY2ZmYmI1OGJl
                                • R
                                  raineysky
                                  Thank You, Thank You. It works great!!!
                                  • S
                                    small08
                                    Outstanding Sam,thank-you for moving this forward!
                                    • utilerU
                                      utiler
                                      Very nice work, Sam. Your ability to structure a script for easy interpretation is wonderful...!
                                      Just Curious...
                                      • kenK
                                        ken
                                        Sam
                                        Thanks for a great plugin that does everything required to add bolts to a project.
                                        And another thanks for writing plugins that are easy to follow, allowing me to gain knowledge from your scripts.
                                        Ken
                                        • J
                                          jonorman
                                          I`m stunned... This is way beyond my expectations 😍
                                          • J
                                            jpalm32
                                            Wow!! What a time saver. Thanks.
                                            • 6
                                            • 3 / 6
