    [Plugin] Bolt Maker (Final Update 7-Feb-2012)
    101 Posts 31 Posters 95.9k Views 31 Watching
    • sdmitchS
      sdmitch
      Ken, That seems like a reasonable feature. I'll investigate the possibilities.
      http://sdmitch.blogspot.com/
      • sdmitchS
        sdmitch
        Bolt Maker X offers an additional bolt location option for situations where non-rectangular components/groups are envolved and a repeat option to allow the placement of bolts of the same specification.
          raineysky
          Thank You Sam
            Michaelv
            Awesome! Here is some Mac testing.
            Couple little things, see picture:
            When the bolt length is across a profile, it adds a big length of thread. Whether I use location or offset.
            If I use offset with the cylinder it doesn't work too well, but you know that and it is why we can now use absolute location and that works great.
            In the mac option box, the size is very small when implemented like that, so the option "Locate by offset" yes/no becomes "Locate by" yes/no, I suggest "location" Offset/Pick (see PM)
            • sdmitchS
              sdmitch
              The problem with the "thread" is the shape of the bottom group. The bolt has to go in and out of the group twice and does not find the faces in a top down order thus causing the problem. I am aware of the problem and I'm working on it.
                Michaelv
                OK thanks
                • sdmitchS
                  sdmitch
                  To all Bolt Maker users: Bolt Maker XII - The final edition has been posted. It corrects the problem with multiple entry and exit point on any given group or component. It even allows and handles non-parallel faces. A fixed length option has been added so that bolts that do not require a nut can be placed. Check out the updated tutorial for further clarification.
                  Error 404 (Not Found)!!1
                  (docs.google.com)
                    raineysky
                    Thank You, Thank You. It works great!!!
                      small08
                      Outstanding Sam,thank-you for moving this forward!
                      • utilerU
                        utiler
                        Very nice work, Sam. Your ability to structure a script for easy interpretation is wonderful...!
                        Just Curious...
                        • kenK
                          ken
                          Sam
                          Thanks for a great plugin that does everything required to add bolts to a project.
                          And another thanks for writing plugins that are easy to follow, allowing me to gain knowledge from your scripts.
                          Ken
                            jonorman
                            I`m stunned... This is way beyond my expectations 😍
                              jpalm32
                              Wow!! What a time saver. Thanks.
                              • bmikeB
                                bmike
                                very nice...
                                just tested it and it will come in handy for my timber to steel connections.
                                i did notice that if bolt 2 components together, it will update all components in the model with the holes, regardless of if those components were part of the bolt assembly. small niggle, and something i can work around, for sure.
                                nice work!
                                • sdmitchS
                                  sdmitch
                                  Of course that's the nature of components. Editing one changes all. Before using Bolt Maker, right click on each and choose "Make Unique". Groups don't have that problem.
                                  • EscapeArtistE
                                    EscapeArtist
                                    Very nice plugin. Thank you!
                                    • K
                                      ksor
                                      @sdmitch said:
                                      OOPS!!!! Sorry Bolt Maker fans. Dispite what I thought was adaquate testing, I found a problem while playing around with the plugin this morning. It has been corrected and a new copy posted.
                                      Hi younger brother !
                                      You say it's the file is updated but where is the updated file placed ?
                                      Best regards
                                      KSor, Denmark
                                      Skype: keldsor
                                        Most logical authors put the current file download-link on the first post in the tool's thread.
                                        So look there.
                                        It's quite easy to add a link to that very page in the post announcing the update - see most of my scripts' threads...
                                        • K
                                          ksor
                                          So look there.
                                          I allready HAVE that file - so it's OK !
                                          But normaly you can't place a new posting as the first posting i a thread - right ?
                                          You have to EDIT the first post
                                          Best regards
                                          KSor, Denmark
                                          Skype: keldsor
                                            Correct - the author owns the first post [usually where the first download link as given]... so he can edit that post later if the script is updated.
                                            So if the file changes he updates the script on the first page and the thread's title to suit.
                                            The Plugins Index 'sniffer-dog' spots titles starting with [Plugin] and also notices any changes to them for version/date etc so the index is auto-updated...
                                            • 3 / 6
