    [Plugin] Bolt Maker (Final Update 7-Feb-2012)
    101 Posts 31 Posters 86.3k Views 31 Watching
      raineysky
      Thank You Sam
        Michaelv
        Awesome! Here is some Mac testing.
        Couple little things, see picture:
        When the bolt length is across a profile, it adds a big length of thread. Whether I use location or offset.
        If I use offset with the cylinder it doesn't work too well, but you know that and it is why we can now use absolute location and that works great.
        In the mac option box, the size is very small when implemented like that, so the option "Locate by offset" yes/no becomes "Locate by" yes/no, I suggest "location" Offset/Pick (see PM)
        • sdmitchS Offline
          sdmitch
          The problem with the "thread" is the shape of the bottom group. The bolt has to go in and out of the group twice and does not find the faces in a top down order thus causing the problem. I am aware of the problem and I'm working on it.
          http://sdmitch.blogspot.com/
            Michaelv
            OK thanks
            • sdmitchS Offline
              sdmitch
              To all Bolt Maker users: Bolt Maker XII - The final edition has been posted. It corrects the problem with multiple entry and exit point on any given group or component. It even allows and handles non-parallel faces. A fixed length option has been added so that bolts that do not require a nut can be placed. Check out the updated tutorial for further clarification.
              Error 404 (Not Found)!!1
              (docs.google.com)
                raineysky
                Thank You, Thank You. It works great!!!
                  small08
                  Outstanding Sam,thank-you for moving this forward!
                  • utilerU Offline
                    utiler
                    Very nice work, Sam. Your ability to structure a script for easy interpretation is wonderful...!
                    Just Curious...
                    • kenK Offline
                      ken
                      Sam
                      Thanks for a great plugin that does everything required to add bolts to a project.
                      And another thanks for writing plugins that are easy to follow, allowing me to gain knowledge from your scripts.
                      Ken
                        jonorman
                        I`m stunned... This is way beyond my expectations 😍
                          jpalm32
                          Wow!! What a time saver. Thanks.
                          • bmikeB Offline
                            bmike
                            very nice...
                            just tested it and it will come in handy for my timber to steel connections.
                            i did notice that if bolt 2 components together, it will update all components in the model with the holes, regardless of if those components were part of the bolt assembly. small niggle, and something i can work around, for sure.
                            nice work!
                            • sdmitchS Offline
                              sdmitch
                              Of course that's the nature of components. Editing one changes all. Before using Bolt Maker, right click on each and choose "Make Unique". Groups don't have that problem.
                              • EscapeArtistE Offline
                                EscapeArtist
                                Very nice plugin. Thank you!
                                  ksor
                                  @sdmitch said:
                                  OOPS!!!! Sorry Bolt Maker fans. Dispite what I thought was adaquate testing, I found a problem while playing around with the plugin this morning. It has been corrected and a new copy posted.
                                  Hi younger brother !
                                  You say it's the file is updated but where is the updated file placed ?
                                  Best regards
                                  KSor, Denmark
                                  Skype: keldsor
                                    Most logical authors put the current file download-link on the first post in the tool's thread.
                                    So look there.
                                    It's quite easy to add a link to that very page in the post announcing the update - see most of my scripts' threads...
                                      ksor
                                      So look there.
                                      I allready HAVE that file - so it's OK !
                                      But normaly you can't place a new posting as the first posting i a thread - right ?
                                      You have to EDIT the first post
                                      Best regards
                                      KSor, Denmark
                                      Skype: keldsor
                                        Correct - the author owns the first post [usually where the first download link as given]... so he can edit that post later if the script is updated.
                                        So if the file changes he updates the script on the first page and the thread's title to suit.
                                        The Plugins Index 'sniffer-dog' spots titles starting with [Plugin] and also notices any changes to them for version/date etc so the index is auto-updated...
                                        • guanjinG Offline
                                          guanjin
                                          @bmike said:
                                          very nice...
                                          nice work!
                                          Too strong
                                          • guanjinG Offline
                                            guanjin
                                            First select line prompt
                                            Edge does not belong to the selected Surface
                                            Too strong
                                            • 3 / 6
