    Need superfast Kerkythea related support
    extensions
    3 Posts 2 Posters 466 Views 2 Watching
    • dereiD Offline
      derei
      I made a very complex model at home and I need to render it at the office. At home I have TwilightRender, so I set up the scene, materials, light, render method, everything. Next, I exported it as XML and I try to render it in kerkythea 2.5.2
      The problem is that in TW i chosen Progresive (9) as render preset, but in KT it renders biased. Interesting is that at home KT renders progressive. How to set KT at my office to render progressive, as TW does?
      I installed KT at home and at the office in same manner, no setting done. The only difference is that my PC is 32bit and at the office is 64bit.
      Please, I need help ASAP ๐Ÿ˜ฎ
      Thank you very much.
      DESIGNER AND ARTIST DEREI.UK
        tomasz
        Rendering\Start >>>
        in
        Settings >> select "17. Path Tracing - Progressive" (or other progressive method)
        If it is exterior then 17 will do. If something more complicated you can chose BPT or MLT (18..20)
        • dereiD Offline
          derei
          Rendering\Start >>>
          in
          Thank you very much. It's done.
          I had no time to read user manual, is the first time ever when I use it for rendering... and I was in a big hurry.
