    Newbie, batch push/pull?
    5 Posts 3 Posters 410 Views 3 Watching
      skylonda
      Pardon this , my Sketchup experience is mainly with architecture visulizations (all right angles). I'm trying to add thickness to this spiral form , which seems possible with a push-pull on each triangular section to the desired offset- Is there a way to preform the process in one step?
      meru explode.skp
      • boofredlayB Offline
        boofredlay
        Joint Push Pull is what you need John.
        http://forums.sketchucation.com/viewtopic.php?p=42783#p42783
          Eric beat me to it. But scale it up a lot before you do it. It's extremely tiny as it is.
          Edited: Maybe not JPP. This is what I got and it seized up SU.
            skylonda
            Thanks!, that did work after a while. Glad to have found this source for plugins and help!
              Did that give you thickness of did you let the plugin remove the original faces? It looks like the latter.
