    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Export Cpoints to CSV v1.0 20110913
    28 Posts 6 Posters 17.6k Views 6 Watching
    • jemagnussenJ Offline
      jemagnussen
      Hi again,
      Just a question, is it somehow possible to force the numbers of decimals to say fixed 3 decimals on all the 3 figures (LLZ)?
      Best regards
      Jesper
      HP ZBook 15, Windows 10 64 bit
      Intel Core i7-6820HQ @ 2.70GHz
      32 GB Ram
      NVIDIA Quadro M2000M
        @jemagnussen said:
        Hi again,
        Best regards
        Jesper
        To export to 3dp always including trailing .000 would be possible... BUT the XYZ code would need revisiting - I'll come back later today when I have a moment...
          Here's the updated version
          (c) TIG 2011
          Type
          Exportcpoints2tsv.new
          in the Ruby Console.
          Exports all Cpoints is a Selection to a X,Y,Z 'TSV' file.
          The sep="\t", the decsep=',' and ext='tsv'.
          Change decsep='.' IF you want 1.234 rather than 1,234 OR run with arguments
          as shown below...
          Model Units are used and get exported to the TSV in say meters as 1,234 -
          it always forces 3dp even when not needed - e.g. 0,100
          Check that your locale Excel uses ','/'.' matching your output.
          You can affect output by adding an argument to the command line, e.g.
          It returns XYZ format by default BUT if you type
          Exportcpoints2tsv.new 1
          it will then use YXZ format.
          To change from ',' to '.' as the decimal separator, type
          Exportcpoints2tsv.new 2
          To change from ',' to '.' as the decimal separator AND use YXZ, type
          Exportcpoints2tsv.new 3
          1.0 20110914 First issue.
          1.1 20110915 Forces 3dp always, command-line argument to change format.Exportcpoints2tsv.rb
            jemagnussen
            Hi TIG,
            Voila... that did the trick, now I get the decimals, also from the model that is geolocated so this is really a big help. Can't thank you enough for your kind assistance.
            Have a lovely day,
            Best regards
            Jesper
            32 GB Ram
              I get there eventually ๐Ÿ˜‰
              • W Offline
                wsellers89
                Sorry to bother you, but I got referred to this post from the newbie section. I had asked the following:
                I am laying out a porous plate and was wondering if there is an easy way or perhaps a script that will read the construction points (e.g. centerpoints) of each of the circles representing the holes. If it could write out the points to a file would be great, but if it would print to the console -- I could write them down. There are a couple of hundred holes that is why I would like to automate this.
                Operating system: Mac OS X
                SketchUp version: V8
                This script sounds exactly like what I need. I placed the ruby script in the Main folder:
                MacHD/Applications/Library/Application Support/Google SketchUp 8/SketchUp/plugins/
                but when I relaunch SketchUp I don't see the script in the Plugins pull down menu. Am I missing something?
                Sincerely,
                Bill
                  The instruction says
                  @tig said:
                  Type
                  Exportcpoints2csv.new
                  in the Ruby Console...
                  Open the ruby console from the window menu and simply copy paste that line there (at the bottom) then press enter
                    As Gaieus said... it's a rarely used tool, so it is used without a menu item - as explained in the instructions on the download page...
                    Type
                    You can export any selected cpoints to CSV using this 'Export CSV' tool...
                    To mark all of the selected Arcs/Circles centers with cpoints, BEFORE you do that final CSV export, you can run this one liner: Copy/Paste the code into the Ruby Console + <enter>
                    m=Sketchup.active_model;ae=m.active_entities;s=m.selection;as=[];s.each{|e|next unless e.kind_of?(Sketchup;;Edge)and e.curve and e.curve.kind_of?(Sketchup;;ArcCurve);as<<e.curve};as.uniq.each{|ar|ae.add_cpoint(ar.center)}
                    A cpoint is added to every Arc/Circle's center for you, select them.
                    The 'Export CSV' tool filters for only cpoints so you don't need to be too carefully making the selection as long as you include the cpoints you want...
                    • 2 / 2
