    [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20
    55 Posts 29 Posters 122.1k Views 29 Watching
    • fredo6F Offline
      fredo6
      NEW RELEASE: ReportLabelArea 3.2a - 05 Feb 20
      ReportLabelArea 3.2a introduces an evolution in the reporting by material. It takes into account the material of the container objects, which are automatically assigned to faces which have no material defined.
      It is available as of FredoTools v3.8b and also requires LibFredo6 v9.5e or above.
      See FredoTools plugin home page for Download.
      See also main post of this thread for User Discussion.
      Fredo
        Catalyst
        Annotation 2020-03-17 175806.pngI have a problem with the latest version where the HTML table is collapsed.
        I can only read the 1x line at the time. (See screenshot)
        The only option is to export the report as a CSV in order to be able to read it.
        • fredo6F Offline
          fredo6
          There is no screenshot attached...
          But can you resize the dialog window ?
            Catalyst
            Yes, I can resize the window but the table stays collapsed.
            • fredo6F Offline
              fredo6
              I don't even know if you are on Windows or Mac, which version of Sketchup.
              A screenshot would also help.
                barsaglini
                Same problem here, table dont resize with window
                windows 10, sketchup 20.1
                and the table on layout, just show a M
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: ReportLabelArea 3.3a - 17 May 20
                  ReportLabelArea 3.3a fixes issues with display and resizing
                  It is available as of FredoTools v4.0a.
                  Fredo
                  • Y Offline
                    yuyawoang
                    Thank you, that supper helfull ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                      jokingw
                      THX~~GOOD STUFF
                      • K Offline
                        KarelSketchUcation
                        Hello.
                        I use Sketchup8 and after installing Fredo Tools my Report on Areas and Label with Areas functions do not work. Is it possible to find any cause and fix?
                        • fredo6F Offline
                          fredo6
                          Since you have Sketchup 8, you need to take the legacy versions of
                          • FredoTools
                          • LibFredo6
                            Rohean Newcomers
                            Hello,
                            I have Sketchup 2022 and this plugin doesn't seem to work for the area calculations in this version. Is there any chance it will be updated? It would be super helpful for my workflow.
                            Thanks!
                              Rohean Newcomers
                              Hello,
                              Thanks!
                              • fredo6F Offline
                                fredo6
                                Could you be more precise on what does not work?
                                • Z Offline
                                  zahraazawii Newcomers @fredo6
                                  @fredo6
                                  Thank you for your support us Fredo๐Ÿ™๐Ÿป
                                  • 3 / 3
