    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Wooden Zulu battle tank.
    8 Posts 4 Posters 1.2k Views 4 Watching
    • K Offline
      KiraNL
      My first WIP on this forum, i found a website where you could buy blueprints for various vehicles, buildings etc.
      And i thought it would be fun to buy one and model it instead of laser cutting it or making it out of wood.
      Finished 11 pieces so far which make up the barrel and top mount, nothing special but funny to do.
      Next would be the bottom part which is quite more complex, but will get there. ^^
      The result would be a completely working product.
      I just noticed while uploading that one part is a bit off, forgot to fix it for the render, but nothing more then 2 extrudes.
      Results so far:
        It's probably some fine work but when I see those imgshack thumbs I never click them. They load so slowly for me.
        There's another member here who always uses imgshack and it makes for painful page loads.
        But from those little images I see it does look like an interesting project πŸ‘
        • K Offline
          KiraNL
          Fair enough, resized them manually to an acceptable size and included them in my post instead of imageshack.
            Thanks for that πŸ‘
            Is there a final assembled plan that show you end goal?
            • mitcorbM Offline
              mitcorb
              Is this just the first element of a complex war machine?
              • K Offline
                KiraNL
                Well, not that complex, but it takes quite some time because there are no measures on the blueprints and there are alot of pieces left to make... 🀣
                End result is already animated in 3D, from the makers where i bought the blueprint/assembly guide.
                It can be seen here: http://www.youtube.com/watch?v=UhOAkFaWYEA
                But from that end result i want to expand it with more pieces, but first the original with some minor adjustments.
                  rspierenburg
                  Wow. That looks like quite a bit of work...can't wait to see it all finished. After looking at the animation I wouldn't doubt if it was done with Sketchup in the first place.
                  Rob
                  • K Offline
                    KiraNL
                    Rob
                    Could be, i think sketchup is perfectly for things like this, could take some shortcuts, like when it says 32x piece A, i could make piece A just 32x longer, but hey whats the fun in that hehe.
                    We dont have components for no reason. ^^
                    And it looks way cooler in some exploded view if its done like in the blueprints with all the pieces imo.
