    [req] disable section plugin
    3 Posts 3 Posters 295 Views 3 Watching
    • john2J
      john2
      often while switching to different scenes, the section plane get automatically disabled which is really annoying sometimes. Is there a plugin that temporarily disables the section functionality of sketchup? or maybe a hack which involves removal of some program files lol!
      • jolranJ
        jolran
        You have to update the scenes when making changes. That way you set up the scenes any way you like it, regarding hidden geometry, sections , layers etc.
        • thomthomT
          This is the correct way of doing it. Styles and Scenes stores the active cut - make sure you check these settings.
          You can set your styles not to store Section Cut styles.
          (btw, there is not way to set/unset the active section cut via the Ruby API)
