    [req] disable section plugin
    3 Posts 3 Posters 241 Views 3 Watching
    • john2J Offline
      john2
      often while switching to different scenes, the section plane get automatically disabled which is really annoying sometimes. Is there a plugin that temporarily disables the section functionality of sketchup? or maybe a hack which involves removal of some program files lol!
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • jolranJ Offline
        jolran
        You have to update the scenes when making changes. That way you set up the scenes any way you like it, regarding hidden geometry, sections , layers etc.
          This is the correct way of doing it. Styles and Scenes stores the active cut - make sure you check these settings.
          You can set your styles not to store Section Cut styles.
          (btw, there is not way to set/unset the active section cut via the Ruby API)
