    Crossfade plugin
    3 Posts 2 Posters 457 Views 2 Watching
    • D
      dougald
      Hello,
      I am trained as an architect and would like to know if anyone knows how/where a plugin for crossfading between saved scenes? I am showing a progression of building phases with a fixed camera location and a smooth appearing phase(next scene) would be much nicer than it just popping up.
      I am new to this forum but have used sketchup from it's earliest release. this is a great forum and it has helped me out many times without my interaction, but I cannot find if there is a plugin that would "crossfade" between saved scene tabs. I am showing phases of construction to a client and it would be much easier if I could do this in SKP instead of importing images to powerpoint. thanks in advance...
      • TIGT
        You can manually change delay and transition times between scenes - see Model Info > Animation settings.
        You can Ruby code these setting using - Sketchup.active_model.options["SlideshowOptions"]
        giving say
        ["LoopSlideshow", true] ["SlideTime", 0.0]
        and also Sketchup.active_model.options["PageOptions"]
        giving say
        ["ShowTransition", true] ["TransitionTime", 3.0]
        The transitions between scenes can also be adjusted...
        First get a reference to the scene (aka page)
        e.g. page=Sketchup.active_model.pages[0]
        or do it by finding the page 'by name' etc...
        The page.delay_time and page.delay_time= get/set that value, -1.0 says use the default value from options; another value, e.g. 10.0 is a 10 second delay.
        The page.transition_time and page.transition_time= get/set that value, -1.0 says use the default value from options; another value, e.g. 10.0 is a 10 second transition.
        There are also a few plugins to do this for you - search at Smustard.com...
        Please don't 'double post' - I've removed one and merged the text which was essentially the same in both.
        • D
          dougald
          thanks TIG, I'll try those techniques.
          sorry about the double somehow I got some text pasted into a code box and was trying to correct it so it would not be confusing.
