    Select active section plane
    2 Posts 2 Posters 317 Views 2 Watching
    • P Offline
      Phil Rader AIA
      Is there a plugin or a way to select the active section plane i mean make it the selected object to move it with out having to zoom extents to be able to see the "end" or bounding lines of the section plane, and when there are multiple section planes and it's impossible to distinguish which section plane you are selecting. Or is there a way to cycle through the section planes. IE would it be possible for the section plans to be listed in the Outliner for instance so you could name them and be able to select them from the outliner...
      Just think that would be a great idea.
      http://www.philrader.com
        Very limited Section Plane in the API. You can get/set the active cutting plane.
        That only thing you can do is find them and get/set their plane orientation. So your selection cycle would work, but that's about it.
