    [plugin] EdgeFollowMe - UPDATE Aug 30, 2011
    21 Posts 7 Posters 30.6k Views 7 Watching
    • sdmitchS
      sdmitch
      In response to http://forums.sketchucation.com/viewtopic.php?f=323&t=39280
      Now handles closed paths fully.
      The profile to be extruded, must be made into a curve. Use Weld or simuliar
      plugin to combine the entities defining the profile. The profile should be
      at the start of the extrusion path. If a path is pre-selected, the start
      and end will be labled. Use right or left arrow keys to reverse the line
      if needed. A warning will be given if either the plane of the profile is not
      perpendicular to the path and/or if the profile is not at path startpoint.
      You may accept or reject any of these warnings if you want the profile to be
      offset or tilted.
      If a path is not pre-selected, click on the profile and drag
      to extrude the profile to any length and direction. The resulting surface
      is grouped and you are given to option to soften and smooth.
      UPDATED EdgeFollowMe3
      http://sdmitch.blogspot.com/
      • KrisidiousK
        Krisidious
        kool... thanks I'll try it out now.
        doesn't seem to be working on any shape correctly except a circle. seems offset from complex routes and backwards and inside out on squares.
        perhaps a little more instruction? what am I doing wrong?
        By: Kristoff Rand
        • utilerU
          utiler
          Thanks for this one too Sam! I'm frustrated right now because I can't test it out as I'm away from the office this weekend.... ๐Ÿ‘
          Just Curious...
          • sdmitchS
            sdmitch
            Kristoff, If the profile is offset from the path, the extrusion will also be offset. I don't assume that it supposed to be moved to the start point of the path. The profile should be at are near the start point of the path and oriented so that its' plane is perpendicular to the path's first edge. Not even Sketchup's Followme can handle every conceivable path.
            I designed the plugin for the profile and the path to share a common end point since that what the request talked about.
            • KrisidiousK
              Krisidious
              I've been putting the profile right on the path at the start. it still offsets. and the square was closed.
              By: Kristoff Rand
              • srxS
                srx
                Thank you!
                www.saurus.rs
                  3dsmax9
                  cool thank'S
                  • sdmitchS
                    sdmitch
                    Kristoff,
                    The problem with squares is that the start and end points are the same so you have to guess right or undo and try again and use the right/left arrow keys to flip the direction. The extrusion will not be complete because at present closed figures are not accounted for.
                    Would you post the model you have been using so that I can better understand the problem. I personally haven't seen the offset problem when the profile has been connected to the path.
                    • KrisidiousK
                      Krisidious
                      I understand on the squares I'll give it a try in different places.
                      edgetest.skp
                      By: Kristoff Rand
                      • sdmitchS
                        sdmitch
                        Kristoff, thanks for sharing your test model. The "loopy" one just reqired reversing the line before selecting the profile. The large rectangle exposed a bug in the code which I was easily able to fix. The mis-match at the start/end point is as expected since I have not yet attempted to compensate for. It is on the todo list.
                        There are only two things of importance you have to do when using this plugin and that is make sure the profile is at the start of the path and is oriented properly. The profile will parallel the path if it is not on the path. When you selected the "loopy" path with the profile on the wrong end, the extrusion was offset by that distance.
                        Edge Follow Me Test
                        • utilerU
                          utiler
                          Sam, does this only work on a single path?
                          Just Curious...
                          • sdmitchS
                            sdmitch
                            No, you can select any number of connected edges or a curve.
                            • F
                              feryum
                              Follow Me And Keep is really better
                              • utilerU
                                utiler
                                Thanks make, not really getting that to work. do you:
                                1. select profile
                                2. select start point for extrusion then keep picking around a path or points till finished?
                                  how do you finish; double click?
                                ๐Ÿ‘
                                Just Curious...
                                • TIGT
                                  This EdgeFollowMe was meant to be a EdgeFollowMeAndKeep ?
                                  The FAK code is readily amenable to adjustment - swap 'face' for 'curve', and find midpoint of curve.vertices rather than face.vertices etc it should then work much the same...
                                  • sdmitchS
                                    sdmitch
                                    Looks like I have been wasting my time if FAK already does this.
                                    Andrew, Just like Sketchup's FollowMe, select the entire path first then run the plugin and select the profile.
                                    • KrisidiousK
                                      Krisidious
                                      not a waste of time as FAK does faces and it keeps.
                                      By: Kristoff Rand
                                      • TIGT
                                        FAK works on selected face[s].
                                        BUT you could recast some blocks of its code to process a curve's vertices rather than a face's vertices...
                                        • utilerU
                                          utiler
                                          I was hoping to be able to place a profile in place the pick a path, Sam. At times it's easier to do so rather than zoom out to find the path then execute...
                                          I don't think you have wasted your time at all!!
                                          Thanks Sam.
                                          Just Curious...
                                          • sdmitchS
                                            sdmitch
                                            Sorry Andrew but EdgeFollowMe3 is the end of the road.
                                            • 1 / 2
