    Selection Window not visible.
    14 Posts 3 Posters 1.1k Views 3 Watching
    • boofredlayB Offline
      boofredlay
      We have a network license here at work and I just installed SU8 Pro on another machine. Everything works fine except when selecting.
      The selection window is not showing up. You can't see what you are trying to select but it does select like it should.
      We went to update the drivers on the video card, monitor and mouse just in case... all were up to date.
      Thanks for any insight.
      Screenshots of some of the settings.
        Did you try un-ticking the Hardware Acceleration and/or Fast Feedback boxes?
          boofredlay
          Yes and nothing changed. I am really stumped. My only thought is that the Intel HD Graphics can't display it for some reason.
            Could very well be. There isn't anything else left to see in SU. Can you get at any OpenGL settings for the card?
              boofredlay
              I did not see a way but I can check again.
                boofredlay
                Crud, I have to wait another hour and a half as his machine timed out and I don't have his login.
                • AnssiA Offline
                  Anssi
                  Intel graphics have had tons of OpenGL problems over the years, down to being unusable with Hardware Acceleration. If it now works otherwise OK with the missing selection box the only problem, I think it's good news. BTW, has turning Fast Feedback off any effect?
                  Anssi
                    boofredlay
                    No it runs the same with or without fast feedback.
                      boofredlay
                      The card has no OpenGL support.
                      I guess he will have to live with it.
                        Well that's a fine kettle of fish. Maybe the IT dept. Needs to get him a decent card. πŸ˜‰
                          boofredlay
                          Indeed. The thing is though we all just got new computers... why his does not have the same as ours is a mystery. Luckily he does not use it as often.
                            "Specifications subject to change without notice."
                            • AnssiA Offline
                              Anssi
                              If the same graphics card that you others are using is present in the machine, it might be that the driver is missing, so the machine uses the motherboard chip instead.
                              Anssi
                                boofredlay
                                No, they are different graphics cards. Our IT department must have thought we were more special πŸ˜„
