    [Plugin] 2dBoolean ver1.3.1 beta UPDATE 20 dec 2013
    88 Posts 8 Posters 50.6k Views 8 Watching
    • JuantxoJ Offline
      Juantxo
      Sorry, but actually I prefer the code scrambled. The code is not very optimized because I did it to translate to C after.
      I don't use any line of your code. I used a simplicans planar theory. (I taked your one icon, feel free of use my icons)
      Best regards
      • jeff hammondJ Offline
        jeff hammond
        Best regards
        watch out, the πŸ€“ 's around here will unscramble your code and make sure you're telling the truth πŸ’š
        dotdotdot
        • jolranJ Offline
          jolran
          Ok. If you say so.
          That's ok. I don't mind that. 2 min PS for me.
          Ok, about that. I find it somewhat strange to post stuff for free, scrambled. thats not very helpful for other programmers.. Personally I rather tell to much then nothing at all.
          • JuantxoJ Offline
            Juantxo
            Actually I'm working in 2D boolean of polygons in Sketchup because I need for other stuff. I did this plugin using simplicians theory.
            May be could be usefull for someone.
            You need to select two groups with a general planar polygon.
            General planar polygon = A single polygon or a polygon consisting of a set of non-intersecting single polygons.
            DOWNLOAD 2d_simplex_bool.rbz
            http://skelion.net/bool/2dbool.jpg
            • jolranJ Offline
              jolran
              New version 1.3.1 added:
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=39661
              Whole lot is rewritten so there may be lot of things broken. I suggest a lot of testing and report back bugs and wishes πŸ˜„
              Intersections should now be a Little quicker. And some new stuff as well.
              Make sure to read the manual in second post.
              Will try and add to pluginstore later.
              • jolranJ Offline
                jolran
                Manual
                Since ver 1.3.1
                manual_2dBoolean.zip
                  I added it to the SketchUcation PluginStore for you... πŸ€“
                  http://sketchucation.com/resources/pluginstore?pln=2dBoolean
                  You might want to edit the listing and add documentation, release notes etc...
                  • jolranJ Offline
                    jolran
                    Thank you TIG. Really appreciate it!
                    I havent done any update for a long time and must get up to date with how the pluginstore works, more in detail.
                    I suppose I should move the manual there to, perhaps ? Did not manage to downsize it to less then 1.8 mb. 😞
                    • 5 / 5
