    Line Color by Plane?
    8 Posts 3 Posters 569 Views 3 Watching
      rpaul
      Is there any setting, or Ruby, that would allow line colors by plane. The setting for "color by axis" only colors lines along the direct x, y, and z. I'm looking for something that colors lines in the same x, y, or z plane. Any thoughts??
      • P Offline
        Color edges by CPlassais?
          rpaul
          Thanks. I'll take a closer look at it. What I'm really after is being able to filter lines that have the same x,y, or z coordinates. For example, all lines in a particular x-y plane will have the same z coordinate value, and all lines in x-z plane will have the same y coordinate. Looking for something that will filter and color lines that share that same value.
            sdmitch
            rpaul, do you want find and color all edges on a given plane, XY for example, at a specified Z or just all edges on the XY plane at any Z?
            http://sdmitch.blogspot.com/
              rpaul
              Specified z.
              Thanks, Ron
                sdmitch
                Ron, I have just posted a plugin on the Resources>Plugins page that I think will do what you want.
                http://forums.sketchucation.com/viewtopic.php?f=323&t=39735
                  rpaul
                  Thanks Sam. I downloaded it, and it seemed to basically work initially, but now it doesn't seem to anymore. For example, the color by plane function for plane xz will only color one line in the plane (the one with x value only). Nothing comes up in the ruby console, SU doesn't lock or freeze, so I assume the ruby ran ok. Any thoughts?
                    sdmitch
                    rpaul, Please download the plugin again. There was a problem with the previous one.
