    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Plugin]FPS Nav
    38 Posts 27 Posters 61.6k Views 27 Watching
    • W Offline
      weba
      Finally found plugin to allow this, should be like this from the start with, developers never played FPS games?
      But, what I'd really appreciate, would be invert-mouse for free look! I'm one of those weirdos who likes that, maybe in the next release...? ๐ŸŽ‰
        JuanV.Soler
        could it be possible to move an object with the keypad like in Layout ?
        Thanks for the plugin ,._)))
        Edited : I found this plugin from Jim : http://sketchucation.com/forums/viewtopic.php?t=1530
        smart ยก thank_you
          bigjonyz
          Very good effort. if there is a way to reverse the mouse Y axis or sensitivity would be great.
            lonherz
            @ weba and bigjonyz :
            I prefer the y-axis inverted too, and I have obtained this modifying the plugin's code:
            • if you have sketchup opened, close it
            • open the sketchup's "Plugins" folder
            • open the file "FPSNav.rb" in the folder "FPSNav" with a text editor (like notepad++)
            • find this line (about at row 343):
            yRotationTransformation = Geom;;Transformation.rotation(@FPSNav_eye, horizontalAxis, radiansToRotate)
            and change it like this:
            yRotationTransformation = Geom;;Transformation.rotation(@FPSNav_eye, horizontalAxis, -radiansToRotate)
            (the only difference is a minus before "radiansToRotate")
            • save the file and then open sketchup: now the y-axis should be inverted
              Jorgensen
              Can anyone please explain how (if possible) I can mod the script so
              • I can change the navigation to WASD / Q&E without having to use shift?
              • use SPACEBAR to doubble speed?
              • automatic start WASD navigation just by pressing 'w'?
              Thanks ๐Ÿ˜„
              sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
                Jorgensen
                bumb ๐Ÿ˜„
                  Jorgensen
                  Or just change the keys to wasd?
                    ArielC
                    Been waiting this from AtLast, and then Google, and now Trimble...it's been years I wanted to find other options then I discovered Adobe Director.
                    It can import Sketchup files and make it interactive including FPS. Files can be published as a standalone executable file for PC or MAC use (haven't tried publishing as an APP for Ipad use but I know it can be done.) For viewing on the Browser, it requires Adobe Shockwave Player plug-in to run.
                    FPS
                    -navigating using arrow keys
                    -with collision
                    -open swing and sliding doors
                    -add sound
                    -many more
                    Here's a video on a project I was navigating - http://www.youtube.com/watch?v=t-6HQ8erShM
                    And more on my blog if you want to try - http://sketchuptodirector.blogspot.sg/
                      leeyangyang
                      Hi Alan
                      The link seems down?
                      • K Offline
                        kurogriotcabron
                        Alan...is there any way to reverse the upward/downward looking of the mouse control?
                        It is backwards from Unity and others
                          Jorgensen
                          take a look at lonherz post.
                          jorgensen
                            clearsky
                            Awesome plugin! Only one thing i would polish.
                            There are very noticeable jumps in camera rotation while moving with keys and rotating camera in the same time. Would be very grateful to have this fixed.
                            Thanks!!
                            • N Offline
                              natejesus
                              Hey guys! Registered just to say thanks for this plugin. SU is a PITA to use without it. Also, I forked the project on GitHub and contributed a PR to fix camera jumpiness and improve some things. PR is here:
                              https://github.com/AlanChatham/FPSNav-for-SketchUp/pull/2
                              Fork is here:
                              https://github.com/NathanSweet/FPSNav-for-SketchUp
                              You can download my fork here:
                              https://github.com/NathanSweet/FPSNav-for-SketchUp/archive/master.zip
                              Thanks again for the plugin!
                              • E Offline
                                Einstein
                                Thanks ๐Ÿ˜„
                                Adding mesh collisions would be very useful for this plugin ๐Ÿ˜„ Like in the native SU Walk tool.
                                  stefanobignotti
                                  Thank you for the plug-in. IS veru good to navigate. The best it would be invert vertical rotation and no click with mouse. I don't kow if it is possible but it would be very good.
                                  Stefano
                                    bbgolba
                                    This is exactly what I was hoping to find, this solves the reverse up/down left mouse click to look around issue I was having!
                                    This extension is amazing, it really helps to get a real sense of a space. Thank you so much!
                                    • LinearGraphsL Offline
                                      LinearGraphs
                                      Hey there! Any updates? Also, I checked the GitHub links and noticed there's no RBZ to download.
                                      I'd pay good money for a polished extension that does what this does more smoothly and with more features. I'm sure A LOT of people would too.
                                      • I Offline
                                        ibsy Newcomers
                                        There's nothing in the plugin folder with FPSNav.rb??
                                        Help ๐Ÿ˜ž
                                        • 2 / 2
