    [Plugin]FPS Nav
    38 Posts 27 Posters 65.6k Views 27 Watching
      Alan Chatham
      Thanks! I'm glad you like it!
        DANSTAZ
        Hi this is my first post, and i would like to know if you have the time to answer, does this work like a game in terms of say COD where by the camera pans via the mouse (i noticed you said you didn't use a mouse generaly) and the movement is via the wasd keys? THanks for you time and a massive thanks to all the ruby coders.
        • W
          weba
          Finally found plugin to allow this, should be like this from the start with, developers never played FPS games?
          But, what I'd really appreciate, would be invert-mouse for free look! I'm one of those weirdos who likes that, maybe in the next release...? πŸŽ‰
            JuanV.Soler
            could it be possible to move an object with the keypad like in Layout ?
            Thanks for the plugin ,._)))
            Edited : I found this plugin from Jim : http://sketchucation.com/forums/viewtopic.php?t=1530
            smart Β‘ thank_you
            • B
              bigjonyz
              Very good effort. if there is a way to reverse the mouse Y axis or sensitivity would be great.
              • L
                lonherz
                @ weba and bigjonyz :
                I prefer the y-axis inverted too, and I have obtained this modifying the plugin's code:
                • if you have sketchup opened, close it
                • open the sketchup's "Plugins" folder
                • open the file "FPSNav.rb" in the folder "FPSNav" with a text editor (like notepad++)
                • find this line (about at row 343):
                yRotationTransformation = Geom;;Transformation.rotation(@FPSNav_eye, horizontalAxis, radiansToRotate)
                and change it like this:
                yRotationTransformation = Geom;;Transformation.rotation(@FPSNav_eye, horizontalAxis, -radiansToRotate)
                (the only difference is a minus before "radiansToRotate")
                • save the file and then open sketchup: now the y-axis should be inverted
                  Jorgensen
                  Can anyone please explain how (if possible) I can mod the script so
                  • I can change the navigation to WASD / Q&E without having to use shift?
                  • use SPACEBAR to doubble speed?
                  • automatic start WASD navigation just by pressing 'w'?
                  Thanks πŸ˜„
                    Jorgensen
                    bumb πŸ˜„
                      Jorgensen
                      Or just change the keys to wasd?
                        ArielC
                        Been waiting this from AtLast, and then Google, and now Trimble...it's been years I wanted to find other options then I discovered Adobe Director.
                        It can import Sketchup files and make it interactive including FPS. Files can be published as a standalone executable file for PC or MAC use (haven't tried publishing as an APP for Ipad use but I know it can be done.) For viewing on the Browser, it requires Adobe Shockwave Player plug-in to run.
                        FPS
                        -navigating using arrow keys
                        -with collision
                        -open swing and sliding doors
                        -add sound
                        -many more
                        Here's a video on a project I was navigating - http://www.youtube.com/watch?v=t-6HQ8erShM
                        And more on my blog if you want to try - http://sketchuptodirector.blogspot.sg/
                        • L
                          leeyangyang
                          Hi Alan
                          The link seems down?
                          • K
                            kurogriotcabron
                            Alan...is there any way to reverse the upward/downward looking of the mouse control?
                            It is backwards from Unity and others
                              Jorgensen
                              take a look at lonherz post.
                              jorgensen
                              • C
                                clearsky
                                Awesome plugin! Only one thing i would polish.
                                There are very noticeable jumps in camera rotation while moving with keys and rotating camera in the same time. Would be very grateful to have this fixed.
                                Thanks!!
                                • N
                                  natejesus
                                  Hey guys! Registered just to say thanks for this plugin. SU is a PITA to use without it. Also, I forked the project on GitHub and contributed a PR to fix camera jumpiness and improve some things. PR is here:
                                  https://github.com/AlanChatham/FPSNav-for-SketchUp/pull/2
                                  Fork is here:
                                  https://github.com/NathanSweet/FPSNav-for-SketchUp
                                  You can download my fork here:
                                  https://github.com/NathanSweet/FPSNav-for-SketchUp/archive/master.zip
                                  Thanks again for the plugin!
                                  • E
                                    Einstein
                                    Thanks πŸ˜„
                                    Adding mesh collisions would be very useful for this plugin πŸ˜„ Like in the native SU Walk tool.
                                      stefanobignotti
                                      Thank you for the plug-in. IS veru good to navigate. The best it would be invert vertical rotation and no click with mouse. I don't kow if it is possible but it would be very good.
                                      Stefano
                                      • B
                                        bbgolba
                                        This is exactly what I was hoping to find, this solves the reverse up/down left mouse click to look around issue I was having!
                                        This extension is amazing, it really helps to get a real sense of a space. Thank you so much!
                                        • LinearGraphsL
                                          LinearGraphs
                                          Hey there! Any updates? Also, I checked the GitHub links and noticed there's no RBZ to download.
                                          I'd pay good money for a polished extension that does what this does more smoothly and with more features. I'm sure A LOT of people would too.
                                          • I
                                            ibsy Newcomers
                                            There's nothing in the plugin folder with FPSNav.rb??
                                            Help 😞
                                            • 2 / 2
