    Messed up model
    6 Posts 2 Posters 366 Views 2 Watching
    • voljankoV Offline
      voljanko
      I would like to know ,what is wrong with this model.
      It is causing me a bugsplat in some functions (self intersect function).
      group.entities.intersect_with false,transformation, group.entities,transformation, true, group.entities.to_a
      Sometimes Sketchup detect it and offer to fix error,but I cannot repeat this situation.
      This model is a part of bigger model and I have isolated the issue to this small piece.
      I would like to detect this kind of errors without bugsplat.
      messedup.skp
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        The SKP contains a surface that is 'flat' and divided by several hidden lines [why?]
        Why would you want to intersect it with itself? There would a be a nil result ?
        The only arguments you could try changing are the first and last but one...
        • voljankoV Offline
          voljanko
          Try to delete all the coplanar edges that are on this model and you will have only 1 face.
          Then try to select all (edited) and make the intersect with selected (with the right button mouse menu).
          The message will be that is nothing to intersect,but the face will be divided in many faces.
          I think that this is because of the Sketchup tolerance of the coplanar faces(the points of the edges are not on the same plane).
          Only to detect such deviations.
          If it is all regular,nothing happen.
          If the geometry will change,something was wrong.
          If bugsplat occurs,the model has some serious problems and can affect other functions too.
            Works fine for me πŸ˜•
            This 'intersecting' will never 'remove' coplanar edges - there are many examples of code that do however... see Cleanup, http://forums.sketchucation.com/viewtopic.php?f=323&t=33473&p=295717&hilit=erase+coplanar+edges#p295717 etc etc...
            • voljankoV Offline
              voljanko
              Ok,what about this one.It seems all clear,but is not.It has some irregularities.If you delete one edge,the face will be deleted and if you draw back the edge,the face will not come back.This means that the points of the edges are not on the same plane.
              I don't want to remove coplanar edges but to detect this kind of models (or entities).What to do to detect it?
              mestup2.skp
                If you erase a long edge and draw another one there is no new face, if you erase a short edge and draw another one there is a new face.
                This s is a common issue with manually drawn faces where tiny tolerances cause issues, BUT the edges are coplanar enough to keep a face!
                πŸ˜•
