    Move an edge?
    13 Posts 6 Posters 1.1k Views 6 Watching
    • daikuD Offline
      daiku
      This seems so basic, but how do you move an edge? It does not have a transform! method. I tried transforming the two point3d objects of the two vertices, but could not get it to work.
      Clark Bremer
      http://www.northernlightstimberframing.com
      • jolranJ Offline
        jolran
        Heh πŸ˜„ good question, havent tried. Maybe you will have to group the edge temporarely?
        • Dan RathbunD Offline
          Dan Rathbun
          Entities.transform_by_vectors
          and
          Entities.transform_entities
          mention that you must be in the correct edit context.
          I'm not here much anymore.
            Dan Rathbun
            Geom::Point3d objects are an abstract class. Meaning that a Sketchup::Model does not have these objects in it's Entities.
            Only subclasses of Sketchup::Entity can be stored into the model. Most of what you "see" in a model, are subclasses of Sketchup::Drawingelement (which is a child class of Sketchup::Entity.)
            You would need to transform a Sketchup::Vertex, not a Geom::Point3d object.
            • daikuD Offline
              daiku
              But Sketchup::Vertex is not a subclass of Drawingelement, and does not respond to transform!
              Clark Bremer
                Dan Rathbun
                Sketchup::Vertex.superclass
                Sketchup::Entity
                There are many objects "in the model" that are not subclasses of Sketchup::Drawingelement
                examples:
                Sketchup::Layer Sketchup::Page Sketchup::Material
                etc.
                Only Group and ComponentInstance have a transform!() method.
                But that does NOT mean you cannot apply a transformation using the methods in the Entities object...
                • daikuD Offline
                  daiku
                  OK, So I need to put all the edges I want to move into an entities container, and then use the container's transform methods. Can I put existing geometry into an entities container? It seems that the only way to add an edge is to pass in the endpoints, and it will return the resulting edge. Doesn't seem like this will add the original edge, but rather create a new one.
                  Clark Bremer
                  • daikuD Offline
                    daiku
                    Misunderstood how entities.transform_entities works. It's a method of an existing entities container (in my case, a comp def). You pass it the transform, and an array of entities to be transformed. Moving forward again!
                    Clark Bremer
                      The API is badly phrased....
                      You are making it seem more complicated that it is or needs to be...
                      You can group.transform!(transformation) and ditto for instances and point3d [useful if you are using them to construct edges etc].
                      You can't .transform! an edge or a face etc.
                      You can use one of the two entities methods to transform entities and vertices.
                      The entities need to be the entities where the listed objects are... so let's say we have an array of edges to be translated called 'edges' that should all be in the same 'context'...
                      tr=Geom::Transformation.translation(Geom::Vector3d.new(0,0,1))
                      to move everything up in the z 1".
                      edges[0].parent.entities.transform_entities(tr, edges)
                      all of the edges move up 1"
                      Now let's assume we have an array of faces that we want to move in the same way - one way is to move their vertices [you could of course get the faces and their edges in an array and .uniq! it, then transform those as an alternative]
                      verts=[] faces.each{|face|verts << face.vertices} verts.flatten! verts.uniq! faces[0].parent.entities.transform_entities(tr, verts)
                      this method is very common.
                      The other method is entities.transform_by_vectors(objs_array, verts_array)
                      If the vector is the same for each object you could use the ents.transform_entities(translation_transformation) method, but this alternative allows you to manipulate an array [of say vertices] by individual vectors en mass - you need to compile two arrays - an array of objects (which are often vertices) and an array of matching vectors - one for each object to be transformed; this is useful when the vertices need to move by different amounts - see my DropVertices ruby for an example of this...
                        Dan Rathbun
                        TIG ya might as well break down and write up a Transformation tutorial for the new SCF section.
                        • sdmitchS Offline
                          sdmitch
                          I have struggled with this problem also. When I use the vector transform to change the z value of a curve vertex by an offset or absolute amount, it seems to work as expected. But, trying to do the same with the x or y value, gives some rather strange results and I'm baffled as to why.
                          http://sdmitch.blogspot.com/
                            Moving one vertex and then perhaps another will often have a quite different results, compared to moving them all in one fell swoop with the entities. transformation methods that do all of the changes together...
                              Plus - it's much much faster to perform one big entity transformation instead of many.
