    Self intersect
    8 Posts 3 Posters 508 Views 3 Watching
    • voljankoV Offline
      voljanko
      I'm trying to intersect a group with itself like this:
      group.entities.intersect_with false, group.transformation, group.entities,
         group.transformation, true, group.entities
      but with a type mismatch error.
      What is wrong,how to intersect a group with itself?
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        From the user comments at the bottom of the Entities class:
        intersect_with is a little confusing. The parameter entities1 needs to be an Entities object. The parameter entities2 needs to be a single Entity, or an array of Entity - but NOT and Entities object. Better parm names would be "output_entities" and "entity_list"
        • voljankoV Offline
          voljanko
          Now it is ok,thanks.Here is the code:
          transformation = Geom;;Transformation.new
          faces=[]
          group.entities.each do |entity|
             if entity.is_a?( Sketchup;;Face)
                faces.push entity
          group.entities.intersect_with false, transformation, group.entities,transformation, true, faces
          p.s.where do you read the user comments of the API?
            group.entities.intersect_with false, group.transformation, group.entities, group.transformation, true, group.entities.to_a
            Should also work without having to filter out entities.
            • voljankoV Offline
              voljanko
              Yes,but transformations should be "new",otherwise the intersection lines are displaced.
                At the bottom of the pages in the API docs.
                Mind you, I found that if my browser is set to prefer a non-English language the reader is redirected to a page without the comments.
                The URL that has the comments look like this: http://code.google.com/apis/sketchup/docs/ourdoc/entities.html
                If you are redirected then it's the Google pages trying to be "smart" and redirect you to a localized page - which is nothing but the very same page as the English, just without the comments.
                Annoyingly one has to change one's browser settings to prefer English first.
                  The API comments are at the end of each section and might be over more than one 'page' if there are several of them.
                  Using 'new' transformations, without arguments, sets it to the ORIGIN [0,0,0] - which may work OK.
                  But using the 'group.transformation' for both required transformations to ensure that the group's geometry intersects with itself, and it returns the intersection geometry in the same location should work ? Perhaps not if the group has been moved ?? πŸ˜•
                  • voljankoV Offline
                    voljanko
                    Grrr,I hate the "smart" pages. 😠
                    There are no comments on my API pages.I will try to change setting in my browser.
                    I have tested it... and it is only ok, if both the transformations are "new".
