    GeoSketch error
    6 Posts 3 Posters 526 Views 3 Watching
      rock1
      I installed geosketch in my plugins folder, unfortunately i'm getting the following error when i start sketchup
      no such file to load -- GeoSketchFree/GeoSketchFreeLoaderError Loading File GeoSketchFree.rb
      Signature removed by SCF Admin
      • mitcorbM Offline
        mitcorb
        Is it a zipfile? Could there be something amiss in the extraction and installation?
          rock1
          yeah its a zip file, it contains one rb file and a folder having the support file.
            http://cogent3d.com/2010/12/tacforge-geosketch/
            Email the support at the bottom right of the page.
            • mitcorbM Offline
              mitcorb
              Standard practice is to place both in the Plugins folder. Go to Window>Extensions see if there is a check box to select. Go to View>Toolbars see if there is a toolbar to activate.
              I happen to use Winzip. I actually place the zip file in my plugins folder and right click, select winzip in the flyout and select extract to here in the second flyout. You may not want to do this. It is just what I do. And if I wish to keep the zip there, I do. If I wish to delete it, I do.
              EDIT: I made the obvious assumption about the deployment of zipped files. If this is not the solution, do indeed follow Rich's suggestion. 👍
                rock1
                I've mailed to the geosketch guys as advised by Rich. Awaiting reply 😄
