    Window tabs placement
    17 Posts 2 Posters 1.2k Views 2 Watching
    • M
      mwm5053
      SU 8 free, Win XP
      Hi everyone I've been using SU for a while now and somewhere along the way I lost the ability to place the window tabs- layers, material, entity info and what have you to the top of the screen. I don't know if it's a plug-in I installed or what. Very annoying to have them chained together in the drawing area.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Do you have your SketchUp window maximized? If so, click on the button with the two little squares between the - and the X. Then resize the window so there's space above it to allow you to fit the various "tabs" in. I have keep my SketchUp window sized so the drawing space is about the same proportions as a letter sized sheet of paper. this gives me room to stack all those tabs on the right side outside the drawing space and not overlapping any tool bars.
        http://farm7.static.flickr.com/6195/6034735743_7435f566ce.jpg
        • M
          mwm5053
          Thanks Dave I'll do that.
          Walt
          2011 iMac
          V2 Twilight
            Let me know if I guessed right. 😉
            • M
              mwm5053
              A little info on my computer. Using an old laptop Hp workstation with a wide screen second monitor.
              I tried your idea and the tabs only move to the top of the screen when they are right next to the SU screen. Any further away and they pop to a position 1 1/2 " from the top of the monitor. There doesn't seem to be a problem with model info or preferences or any tool bars. just the window tabs. And the funny thing is they act normal on the laptop screen. I reinstaled SU 8 and made sure my drives for the monitors were up to date.
              https://lh5.googleusercontent.com/-dZR_Eqe46oE/Tkkjav6hvSI/AAAAAAAAAhw/NxV9aV4vP3c/s400/screen%252520shot%2525201.jpg
              https://lh4.googleusercontent.com/-yCBybXten00/Tkkj2nEUQRI/AAAAAAAAAiA/yLsuJO6HExQ/s400/screen%252520shot%2525202.jpg
              So I don't know maybe just live with it the way it is I guess.
              Any ideas please let me know.
              Walt
              2011 iMac
              V2 Twilight
                Walt, this won't be something that is adjusted in Model Info or Preferences. If you make the drawing window slightly narrower, what happens then? Or what if you make the tabs a little narrower? To do that you need to have them expanded but then you should be able to push their right side to the left a bit.
                Dave
                • M
                  mwm5053
                  I did a short video (I'm a terrible typist) better to see than explain for me.
                  https://picasaweb.google.com/lh/photo/-frF4ce4ifnnJRMUoeSr5A?feat=directlink
                  Thanks for your help
                  2011 iMac
                  V2 Twilight
                    Walt, I get a message indicating there's nothing to see or I don't have access to your image/video. Is there a share setting you need to set?
                      Walt, I did a quick video capture of mine.
                      http://www.flickr.com/photos/8294157@N08/6047886444/
                      • M
                        mwm5053
                        I think I fixed it sorry.
                        2011 iMac
                        V2 Twilight
                          Picture is indeed worth a thousand words. So you're having trouble getting the the tabs into the title bar area. I just tried that and they go there just fine on my computer. I wonder why not on yours.
                            I shot another video showing mine doing what yours won't.
                            http://www.flickr.com/photos/8294157@N08/6047921892/
                            http://www.annotatedmst.com/episodes/catalinacaper/johnson.jpg
                            "Very intersting..."
                            • M
                              mwm5053
                              Really not sure they were fine for the longest time using SU just wondered if others had that happen.
                              This is a great forum.
                              2011 iMac
                              V2 Twilight
                              • M
                                mwm5053
                                Well I got it figured out and thought I should share in case someone else finds this puzzling. The layers, entity info, materials, components and etc. must have different behavior or coded different than Model info and Preferences dialog boxes one because they collapse (great idea on the SU people). When multiple monitors are used like mine, laptop being 1024x768 and wide screen second monitor is 1600x900 for watching movies and games or SU. The screens have to be 768 pixel or lower, any higher than that and those tabs will not move to the top or bottom of the screen that is more than 768 pixel.
                                If in the Windows XP Display Properties settings tab the monitor that is 900 pixels aligns with top of the 768 pixel monitor the tabs will go to the top of the screen but not to bottom, vise versa if they align at the bottom the tabs will go to the bottom but not to the top.
                                I don't know if that's clear to anyone but I spent two days on this and that's what I found to be true.
                                Dave thanks for your imput
                                2011 iMac
                                V2 Twilight
                                  Hi Walt, I'm glad you got it sorted out. I'm not sure about the monitor resolution thing, though. My primary monitor is 1200 high (1900 wide) and my secondary is also 1200 (by 1600 wide).
                                  • M
                                    mwm5053
                                    WOW those are some big screens. So maybe it's not restricted to 768 like I thought maybe they just have to be the same height. I don't know but thanks for your help once again.
                                    2011 iMac
                                    V2 Twilight
                                      I don't know. Maybe they do have to be the same height. Those happen to be the native dimensions of my screens.
