    Animation rendering plugin
    2 Posts 2 Posters 269 Views 2 Watching
    • N
      nightshift
      I've been using the Proper Animation plugin to do some object animation in sketchup. I wanted to export the animation in a video file but the animation doesn't work with the sketchoup export method. Is there any free plugin that can do the rendering for object animation? I am not looking for a full feature plugin just something that will do object animation.
      Thanks in advance.
      • StilTegS
        StilTeg
        Use the export feature from proper animation, you will get many jpg files. You may then compile those latter into a video file ...
        doing technical engineering on SketchUp ... without plugins
