Animation rendering plugin
I've been using the Proper Animation plugin to do some object animation in sketchup. I wanted to export the animation in a video file but the animation doesn't work with the sketchoup export method. Is there any free plugin that can do the rendering for object animation? I am not looking for a full feature plugin just something that will do object animation.
Thanks in advance.
Use the export feature from proper animation, you will get many jpg files. You may then compile those latter into a video file ...
