    Reverse faces after pushpull??
    8 Posts 3 Posters 685 Views 3 Watching
    • K Offline
      ktkoh
      Drawing counter sunk holes with a rb script and all looks ok except the faces on the inside of the thru hole are reversed and I have not be able to alter the code to fix this. Any suggestions???
      when "C_Sunk"
      #Calculate points for C_Bore
      points_ScrewHead(@xcl[i],ycl,0,(@h_dia/2),dir_y) #@pthd[ ]
      @pthd=@pthd.collect {|point| point.transform(backt)}
      points_Screw(@xcl[i],ycl,(@z1*-1),(@s_dia/2),dir_y) #@ptsc[ ]
      @ptsc=@ptsc.collect {|point| point.transform(backt)}#to component coord
      cface=codef.entities.add_face(@pthd) #Counter Sink Dia
      codef.entities.erase_entities cface  #Erase face for CS large opening
      cface=codef.entities.add_face(@ptsc) # Screw shank Dia
      if @thruHole == "Yes" then cface.pushpull((@edge3L-@z1)*-1) end #Pushes scw dia thru component
      codef.entities.erase_entities cface # Added this because pushpull left face at bottom of CS
      for k in -1...11
      cface=codef.entities.add_face(@pthd[k],@pthd[k+1],@ptsc[k+1],@ptsc[k]) # Adds bevel faces for CS
      end # for k
      Keith
        Why not try flipping the face:
        cface.reverse!
        immediately after you make it...
        and then do something like:
        cface.pushpull(@edge3L-@z1)
        • K Offline
          ktkoh
          I have tried that and to make sure I tried again still reversed. I seem to need a way to identify the faces created with the pushpull and reverse each one. Or else just leave them red. I know the points on each end of the circle just the z value changes could I use face common to 2 edges to find each face and change it??
          Keith
            How about this...
            In code...
            Add a group to the entities holding the main face.
            Add a circle inside group.entities.
            Use face.pushpull on this new circular face to form the basis of the 3d hole.
            You now have all of the faces inside that group so you can use .reverse! on them all, so it's turned "inside out".
            Redraw the circle inside the group [the original will be lost during the pushpull so any earlier reference to it is useless]
            Erase that newest face as the reference to it persists.
            You now have a group containing a cylinder without a top [like an opened tin can].
            Now cut a circular hole in the main face - add the circle onto it and use .erase!, as you have a reference to its face.
            Now you have the main face with a circular hole in it and the rest of the cylindrical 'hole' in a group below it.
            Use .explode! on that group and the things heals together as required... πŸ€“
            • K Offline
              ktkoh
              Here is what I have been trying but the code breaks some rule or rules. I am trying to capture the no of entities created with the push pull and search thru them for faces and reverse the faces I find. On the first hole the no of entities increase from 49 to 84 so I was trying to loop thru those to find faces. error message is #<NoMethodError: undefined method `[]' for #Sketchup::Edge:0x9f13ee4>
              orig_l=codef.entities.length
              #UI.messagebox("Orig no of enities = " + orig_l.to_s)
              fin_l=codef.entities.length
              #UI.messagebox("Final no of enities = " + fin_l.to_s)
              	for j in orig_l.to_i..fin_l.to_i
              	ents = codef.entities[j]
              	if ents[j].typename == "Face" then ents.reverse! end
              end # for j
              Keith
              • Dan RathbunD Offline
                Dan Rathbun
                Because your making changes to the C++ side entities collection from within a loop... the loop looses "it's way" (items get skipped, some get processed more than once.)
                Items in a collection are not necessarily in order like an array.
                You need to copy the orginal collection to an array
                line 2: orig_ents = codef.entities.to_a
                then the final to an array
                line 6: fin_ents = codef.entities.to_a
                then subtract:
                added_ents = fin_ents - orig_ents
                Then iterate that array:
                added_ents.each {|e| e.reverse! if e.is_a?(Sketchup::Face) }
                I'm not here much anymore.
                • K Offline
                  ktkoh
                  Thanks Dan worked like a charm. I can't tell you people on the forum how much I appreciate the help. Books and help files only go so far its help like I get here that makes any thing I come up with possible. I have ideas and I am sure there are ways of getting it done but it takes help like I get here to make it a reality.
                  Thanks All
                  Keith
                    My idea of using a temporary group means that the faces in the group are all that's needed to consider for reversing - so it very quick; if you are making lists of all entities before and after a pushpull then there might be thousands of them to sift through, twice! ... So why not make a group, add a circular face, pushpull it, reverse the faces in the group, re-add a circular face to the group and erase it, then add a circular face to the main-face and erase it to leave a hole over the grouped 'recess', and finally explode the group? It will be much quicker in most circumstances... and 'safer' too...
