    Vray Material
    renderpluginsextensions
    2 Posts 2 Posters 557 Views 2 Watching
    • E
      EDMON242004
      Hi everyone, got a question for the Vray GURUS out there, about the latest SUVray 1.49.01. this is the case... I have two SU files open, one is the components file with vray materials on them and the other file is the scene file (without the components) so what I did is that I copied the furniture in the components file then pasted them on the scene file, but after I pasted them the vray materials on the components I pasted were gone what is left is the diffuse map, the reflection, bump, refraction and displacements were all gone, is this a bug?
      Many thanks
      • andybotA
        andybot
        it is a bug.
        If you copy geometry in SU without vray running, it seems to work. You can use thomthom's vray toys to turn off vray from loading.
