    [req] a good stairmaking plugin
    25 Posts 12 Posters 2.9k Views 12 Watching
    • utilerU Offline
      utiler
      @sdmitch said:
      Well Dave he never asked for it, only about it, so I fealt no compulsion the give it.
      Rock, the plugin in question is attached. You can access it through the Plugins menu. There are 3 options, Normal, Spiral, and U-Shape.
      Normal is just a straight run with a railing on one side. The steps are a group and the rail is a group.
      Spiral is a circular or elliptical stair depending on the Max,Min width input. It is a single group.
      U-Shape now accepts "turn steps" which replace the landing if defined. This is a single group also.
      G'day Sam, nice little plugin!
      I have some ideas for you to add if you could to extend it a little more.... see attached PDF.
      stairMaker.pdf
      Just Curious...
      • charly2008C Offline
        charly2008
        Thank you very much Sam,
        a very useful and time saving plugin.
        Charly
        • sdmitchS Offline
          sdmitch
          Andrew, I will take a look at your suggestion and see what I can do. Some are trivial like asking for and using a given gap between the runs and the height and offset for the handrail. The "in-situ" option not so trivial but I'll see what I can do.
          http://sdmitch.blogspot.com/
          • utilerU Offline
            utiler
            Thanks Sam, appreciate it!
            Also for your u-shape stair maybe add a tread thickness and make treads components... Just helps with edits.
            Well done, mate! simple and very effective tool!
            Just Curious...
            • sdmitchS Offline
              sdmitch
              Andrew, I think I have incorporated all the changes you suggested except make the treads components. Maybe in version 3.
              Stair Maker
              • 2 / 2
