Make Grid Plugin
does anyone know of a plugin that makes grids on a surface?
i am thinking of options like size x,y... and whether the grid is centered on the surface, justified left/right/top/bottom, or offset by a specified amount...
this would be really helpful for creating ceiling grids.
any suggestions are much appreciated. thanks!
mike
These are helpful, and thanks! Was looking for something like this that would create edges rather than construction lines...
Somewhat biased reply, but you could try crosshatching. http://forums.sketchucation.com/viewtopic.php?f=323&t=38637
if it's edges you want. Only work on planar faces.
