    My option editor for vray is not working
    renderpluginsextensions
    4 Posts 4 Posters 3.2k Views 4 Watching
    • N Offline
      noise
      My option editor refuses to open. I tried to unnistall, install the program, nothing. The material editor is ok. The problem has appeared when i switched of one display (i used 2 LCD's now remained one). I have no more ideas, is someone had this problem before please give me a clue.
      • andybotA Offline
        andybot
        which version of vray are you using?
        • EarthMoverE Offline
          EarthMover
          It's probably hiding somewhere due to the dual monitor switch. Sometimes windows get stuck in limbo between the two monitors when you restore to one. Can you find it by using Alt+Tab? If so, tab until you highlight the Vray Options window and once it's the active window (even if you can't see it) try pressing Alt+Spacebar (brings up the window options) you can then hit the "m" key and use the mouse or arrow keys to move the hidden window into view. Might not be the case, but it's worth a shot.
          (Try it also with a visible window first to see exactly what the shortcut keys are doing)
          Content Creator at Skapeup
          • dkendigD Offline
            dkendig
            If you are using version 1.48.66 or later, you can fix this issue by deleting your vfs preferences ini file. It's located in
            Windows 7:
            C:\ProgramData\ASGVIS
            Windows XP:
            c:\Documents and Settings\All Users\Application Data\ASGVIS
            OSX:
            /Library/Preferences/Qt/ASGVIS
            This file is responsible for remembering window size and position, as well as a few other settings behind the scenes. You could also edit the file so that only the part responsible for the options window's position gets removed, but it's easier to just remove the whole thing.
            This issue should not occur in 1.49.01, so if you are using that version, we would appreciate it if you could send us a bug report about this issue: vfswip@asgvis.com
            Devin Kendig
            Developer
