    Ruby How to Select All Connected
    6 Posts 3 Posters 2.0k Views 3 Watching
    • G
      ghandi
      Hello Forum,
      There is a right-click option called "select all connected".
      is it also possible with ruby?
      Thank you
      • TIGT
        Yes, you use the edge method
        http://code.google.com/apis/sketchup/docs/ourdoc/edge.html#all_connected
        or face method
        http://code.google.com/apis/sketchup/docs/ourdoc/face.html#all_connected
        to get an array of the connected edges/faces.
        e.g. assume we have reference to an 'edge'
        all = edge.all_connected model.selection.add(all)
        To find a list of just all connected edges you could filter the array to ignore faces etc... πŸ€“
        • GaieusG
          Have look at this plugin:
          http://forums.sketchucation.com/viewtopic.php?t=14975
          • G
            ghandi
            Thank you very much. It works,
            but i'ts not exacty what I need.
            So I should have changed the question a bit.
            I need to select (all) connected edges to an accurve (created between to edges with Fillet.rb)
            Additionally the selection should not go to further edges or anything, only the two edges and the arccurve.
            So all_connected() wont work.
            (All this is for automatically handing them (the path) over to PipeAlongPath.rb)
            • GaieusG
              If you are asking about ruby methods in order to write your own plugin, I'd rather move the topic to the developers forum. I will definitely not be able to help in this area... 😳
              • TIGT
                I've moved this into the Developers' Forum as it's a general issue...
                You can get info about a curve.
                verts=curve.vertices returns the vertices, so if it's an arc etc then vf=verts.first and vl=verts.last are the end vertices.
                You can also get the start and end edges with ef=curve.first_edge and el=curve.last_edges
                You can get the edges that use any vertex with
                edges=vertex.edges so do that for vf and vl in turn - the array of edges will include the curve's edge so fedges=vf.edges; fedges.delete(ef); fedgeyouwant=fedges[0] ditto for vl/ el
                So you now have a way to find the two edges connected to ends of an curve.
                This assumes you have checked it's a curve, it's not looped etc; and if there isn't a connected edge you get 'nil'. or if there are more than connected edge then only the first one found is returned...
