    Is there a program that alows lights?
    5 Posts 3 Posters 302 Views 3 Watching
    • E Offline
      emanshiu
      Sorry if this is a dumb question but is there any way (via plugins) to use lights in SU? Seems like everything I se is daylit. Thanks!
      • StilTegS Offline
        StilTeg
        did you activate the shadows ?
        doing technical engineering on SketchUp ... without plugins
        • Alan FraserA Offline
          Alan Fraser
          You will need to render the model in order to work with light effects. There are plenty of links on the forum to a whole range of renderers...some free, some fairly pricey.
          There's LightUp, Podium, Kerkythea, Twilight , V-Ray...just to mention a few
          3D Figures
          • E Offline
            emanshiu
            yes I am aware of these renderers but they all seem to just render with a sun. What I bneed is to use artificial light sources like lamps. Is that possible?
              Alan Fraser
              All those renderers have an assortment of lights such as spot or point. They also have the ability to make actual surfaces emit...so you can place a point light inside a lamp shade or make the lampshade itself glow...or both. They're not limited to just the sun by any means.
              3D Figures
