    HELP RENDERING SECTIONS USING VRAY!
    renderpluginsextensions
    3 Posts 2 Posters 4.3k Views 2 Watching
    • T
      TLD
      Hello people, good day.
      I would like to know if it is possible to use Vray to render a section cutout in sketchup. For some reason, anytime I render a view that has a section on sketchup, Vray ignores the section cutout and just renders it like there was no section applied at all....
      Is there any way to solve this, as I cannot render interior shots while looking at the buildings exterior at the same time...
      Thanks everyone 😒 😞
      • andybotA
        andybot
        you have to actually cut your model. Save a copy of your model, run this plugin: http://forums.sketchucation.com/viewtopic.php?t=16038 (you can click on the section cut for the context menu and cut model at section is an option.)
        • T
          TLD
          THANK YOU SO MUCH !!!JUST WHAT I WAS LOOKING FOR
          Let me test this and see how it works....Thanks again andybot πŸ˜„
