    Matched Photo
    10 Posts 5 Posters 1.6k Views 5 Watching
    • G
      guy
      I could do with some help and criticism please. I have rendered a matched photo in Maxwell Render and put it together in Photoshop. Does anyone have a good method of citting around trees? Have tried to use the background layer and use the airbrush behind to limited effect. I have only a little experince in Maxwell though have enjoyed using it so far.
      Any help will be greatly appreciated.
      • Bryan KB
        That looks good to me.
        • J
          jtgrady
          On trees I like to use Photoshops splotched eraser at 50% and randomly hit the edges. It gives it a really nice dappled look.
          • honoluludesktopH
            honoluludesktop
            Guy, I find the lady in the foreground out of scale. Is the object of the render the biggest building on the right? If so I would opp. for a more symmetrical view, may be a tall image with more sky above. I also find the empty left lower portion of the image to be a distraction. The empty sky on the upper left could also use a foreground tree.
            Nice building, will do much to upgrade the neighborhood.
            • G
              guy
              quote="honoluludesktop"]Guy, I find the lady in the foreground out of scale. Is the object of the render the biggest building on the right? If so I would opp. for a more symmetrical view, may be a tall image with more sky above. I also find the empty left lower portion of the image to be a distraction. The empty sky on the upper left could also use a foreground tree.
              /quote
              Thanks for the help and the comments. The lady is part of the original photo, but she can come out,with a fight! I was going to do add more sky though. Alas dont have a good photo from a flatter angle.
              Regards
              • G
                guy
                Problem solved!
                • M
                  matt.gordon320
                  While I don't have any real criticism (It looks good!), I do have a better method of cutting around trees...use the ones I have instead. I can create a dropbox link if you want. I have a couple hundred photoshop alpha channel trees for use with renderings that friend of mine made a while ago, as well as people and brush presets (for black/white people silhouettes) They're absolutely awesome for PS renderings.
                  Let me know.
                  Matt
                  • G
                    guy
                    Let me know.
                    Matt
                    Yes please. You will have to point me towards a good tutorial on how to use them as I have no idea.
                    • M
                      matt.gordon320
                      I'll do you one better. I'll see if I can snag the time to make one myself. I'll see if I can get that dropbox ready tomorrow, and hopefully the tutorial some time next week.
                      Matt
                      • honoluludesktopH
                        honoluludesktop
                        Guess it can't be helped. Upon close examination, because the ground plane is sloped down, her head is above the middle ground people. You could change this with photoshop prior to placing your building into the photo, but then that would be a distortion of the real view. Is it worth the effort to get another photo without any foreground people? If not, I wouldn't worry about it.
