    Upholstery
    15 Posts 7 Posters 3.5k Views 7 Watching
    • david57D Offline
      david57
      Have been trying to learn upholstery with sketchup. 😆
      For the curves i used ruby script Surfacegen.rb.
      Not rendered, yet.
      • K Offline
        KarinaGM
        I'd like to learn to do this too!
        Could you add a little "how to"?
        **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
        -Benjamín Franklin.**
        • david57D Offline
          david57
          Hi KarinaGM,
          Below are two images.
          The first shows the Icon to press to activate Surfacegen.rb and
          that is the equation and other settings I used in the SurfaceGen Options.
          The second is how i stretched out the surface diagonally.
          This was rotated with the mover tool.
          And the rest is History. 😄
          • david57D Offline
            david57
            Here's the formula for a cushion or seat cushion.
            The next one that follows is a round cushion.
              that looks very nice, David.
              • david57D Offline
                david57
                Thanks Dave,
                Im just making guesses and i dont know anything about upholstery. 😄
                I used to be a door builder and glass installer for a local company.
                • K Offline
                  KarinaGM
                  where's the clap, clap, clap?
                  Thanks, I'll go and get this plugin and try.
                  One more question. What did you do for the corners? Shape bender? I guess not
                    All is mathematic and geometry! ☀
                    • K Offline
                      KarinaGM
                      That's what I discovered when I went to download the plugin.
                      I won't be able to use that one!!!
                      Is it too late to learn?
                      • StilTegS Offline
                        StilTeg
                        It is never too late to learn !!!
                        doing technical engineering on SketchUp ... without plugins
                        • david57D Offline
                          david57
                          Here is a picture with the steps that are followed to make
                          a round edge. I used round corners and the icon is circled.
                          The settings are pointed out in red.
                          Its starting to look like Spider Man's suit. 😄
                          • david57D Offline
                            david57
                            I used the Shape Bender script and it worked.
                            • jarynzlesaJ Offline
                              jarynzlesa
                              mark
                              thx for sharing with your knowledge 👍 .
                              http://www.vizualizaceschodiste.mypage.cz/
                              • K Offline
                                KarinaGM
                                Neat! I like it.
                                I'm learning a lot with this
                                • eevaE Offline
                                  eeva
                                  last week i had a similar task... in a quick sketch for a shop i had to visualise a upholstered piece of furniture, of course with curves. i decided to use a picture as the texture, since it was only shown half in the picture and it was just one small detail. worked out well in the picture. unfortunately i cannot show the full picture due NDA, but i guess it is safe to show the furniture.
                                  do not look to close at the far upper left corner, there is something going on with the texture 😉
