    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 230.5k Views 41 Watching
      Jim
      @kyyu said:
      Also the method can't accicently change the instance variable, it's all local.
      Careful here. It is because the type of the parameter is a Float that is can not be accidentally changed. If @scale were almost any other type of object, the local variable scale would be a reference to the passed-in object and changing scale could change @scale.
      It doesn't help to think of Ruby variables a containers for values. Ruby variables are pointers to objects in the computer memory. Here's my attempt at a graphical explanation. It's an over-simplification because different types are treated differently. Floats and Fixnums are not passed by reference, for example. You also need to be aware of the circumstances when a new object is created, or the current object is modified.
      The local variable a refers to the same String object as s.
      • K Offline
        kyyu
        Jim,
        Good point. I knew of variables being a reference to an object, but still confusing at times.
        • jolranJ Offline
          jolran
          Hi Ken. Thoose layers thing are very good ideas! They may or may not be hard to do, not sure yet. But IF they get implemented one could have them as an option? I don't think it should be default behavior of the plugin.
          thanks for the running tutorial in making a plugin. This continued conversation is helpful
          I thought I was babbling nonsense πŸ˜„ But if you like it, I will continue to report and discuss openly.
          Kyyu. Many thanks again for your advice πŸ‘ I think I am at sleep when you guys are active here on the forum.
          Different timezones.
          I will head for doing as you advice. Using @varibles just when needed. I tried the opposit, but it got messy, and inefficient. Your code looks well structured.
          When ordering methods and things right now, I must also think a little bit forward about the next steps.
          Added features like other hatch-types, and bugtracking etc. The "face-creating" part must be a method or a block itself(sort of main code), if I am going to use it with other hatch-types. The subroutine for crosshatches might get a little repetitive code, not sure yet. IF I will be able to do other hatch-types, it might be a good idea to split up thoose, AND the line-hatches in different modules. Calling from the main "face-creating" script. Eventually I might do a fast version
          of crosshatching so you have something to try.
          They say Ruby is an easy language to learn. I haven't got any experience of other languages, so I can't tell.
          However there seams to be many ways to do things in Ruby, and that can get confusing for a newbie.
          Jim. I like your graphic. Visual guides like that is very helpful.
          • jolranJ Offline
            jolran
            Hi. I trying to figure out the "clever" way to setup the structure of the code. If anyone has any comments, I would be most greatful. Having decision anxiety.
            I am little afraid to destroy the structure of current code and getting flamed for doing something inappropriate.
            I'm trying to avoid using @varibles everywhere. I get the impression that could give some troubles later on.
            The simplest way would of course be to repeat the whole last part(linecreation, intersection) without nesting so many methods, but that would probably be cheating. However the script is not that long so I guess it would not be a catastrophy to repeat things.
            Also having trouble grouping. Where as we will have the structure:
            (maingroup)/(hatchgroup1) (hatchgroup2)
            Questions are. Should "face-cloning" be a separate method?
            Should one create a method for only using 1 inputbox getting values twice?(2 promts, 1 box) OVERKILL?
            Another possiblities is to recreate the linehatching and intersection in a submethod calling on @gents?
              Collect all of your dialog data at the very start.
              If the 1st dialog has 'Yes' for 'Crosshatching?' then a second dialog opens with the -ve version of the angle and the same spacing - the user can change these if desired and press OK, or Cancel to skip crosshatching.
              After the dialogs you use the data to make the grouped hatching.
              If there is no crosshatching then the code is as currently.
              If there is crosshatching then you simply run the coder twice.
              However, as explained before - you remove the hatch code into a sub-def method where you pass values this
              def hatch(angle, spacing, gents)
              where 'gents' is ANY entities set that's passed to it [I left it called that because when you move the code into the method the name can remain - however, note how the angle/spacing variables can NO LONGER be @ variables inside the hatch def because they can be different @'s depending on whether you are making a hatch or a crosshatch from dialog input!]
              and to use for the non-crosshatched version
              self.hatch(@angle, @spacing, gents)
              where you pass the @angle/@spacing variables
              and 'gents' is entities of the 'group' that contains the hatching.
              When you have crosshatching you first make 'group' to contain the TWO groups needed.
              Then add two sub-groups
              hgroup=gents.add_group() cgroup=gents.add_group()
              here 'hgroup' will contain the hatching and 'cgroup' the crosshatching
              To make then first make the hatching
              self.hatch(@angle, @spacing, hgroup.entities)
              note how we have passed a different entities set this time
              To make the other part of the crosshatching use
              self.hatch(@cangle, @cspacing, cgroup.entities)
              Note here we have used different @ variables for the crosshatching - derived from the 2nd dialog AND we use the other entities set too...
              By using the sub-def method for 'hatch' you can reuse the code for hatching or crosshatching as the values are remembered separately as @'s for the two types and if there is crosshatching then a simple extra step of making sub-groups inside the main hatch-group is all you need...
              • jolranJ Offline
                jolran
                Thank you TIG! Much appreciated, was a bit stuck.
                I think I understand better now what you meant before. Before when you said "code into a sub-def method", I thought you meant ADDING a method or "doubbling" the code. There's where I was lost, should have asked earlier for help but pride got in the way.
                Very clever solution! And probably quite natural solution for some off you guys in here 😳
                I will digest this and continue. Thanks again.
                  sergey2402
                  Unexpected results of hatching.
                  All hatches are made with the same distance and with the same angle.
                  Maybe is necessary to select not only the face, but also the baseline?
                  (And maybe the baseline can be anywhere in the drawing, not necessary on the face?)
                  • jolranJ Offline
                    jolran
                    Hmm interesting.. I get the same result. Very disturbing. This must be fixed I agree!
                    I was thinking of modifying TIG's script later on so it will copy lines in 2 directions, from center-> out. Or at least be aligned from center. Maybe that will take care of things. Although I have the feeling it has something to do with how the diagonal is created and vector comparison. Eg that it has to do with vertices 0 and 1 (vectorcreation). Depending of how the boundingbox is created, those points will be on different positions.
                    At the moment I'm trying to fix the crosshatching(having some difficulties), so I will look at this later.
                    Thank you Sergey for experimenting and notifying this!
                      Currently the hatching's rotation is calculated relative to the vector formed by the face's first edge - and this is clearly variable.
                      A consistent and simple way would be to make it relative the the X-axis that has been transformed to lie on the face.plane ???
                        At the moment the ;reference-edge' is actually the vector from the face's fist vertex to the second vertex.
                        This bound to be on the face.plane as all vertices are coplanar.
                        To make another vector to use instead you can make that vector and project it onto the face.plane and use that... So
                        p0=face.vertices[0].position p1=p0.clone p1.x=p1.x+1 p1=p1.project_to_plane(face.plane) vector=p0.vector_to(p1)
                        This projects the equivalent of a vector [1,0,0] onto the face's plane...
                        That vector can now be used to base the hatch angle upon...
                        • jolranJ Offline
                          jolran
                          He he. This is bothering me badly. Most annoying.
                          One of my first ideas when I thought about this plugin was to let the user select from a scroll list, Front, Right, Left Back view etc, and have determined pt from bounds according to selection. That of course is not a flexible and smart solution. But maybe viable? Will be troublesome for in between angles.. It's not a good solution...
                          Oh, yeah that's right 😳
                          Do you mean create edge first on X and move to face.plane?
                          Or maybe select a reference edge as Sergey idea?
                          • jolranJ Offline
                            jolran
                            Hmm, no? I must have gotten it wrong. Doesent work in Y,Z axis.
                            • jolranJ Offline
                              jolran
                              Genious TIG!
                              I think I got it right. It work for me in a few tests.
                              Like this, no?
                              pt=face.vertices[0].position
                                    p1=pt.clone
                                    p1.x=p1.x+1
                                    ve=pt.vector_to(p1)
                                    bb=face.bounds
                                    di=bb.diagonal
                                    po=pt.clone
                              I mean is that correct for an update, cause this problem is(was) irritating.
                                You need to trap for the case when the X-axis is parallel with the palne and then use another axis - i.e. offset the y instead of the x value of p1...
                                To do this get the n=face.normal and then use the alternative vector [offset in y] if n.x.abs==1 or n.z.abs==1
                                etc...
                                • jolranJ Offline
                                  jolran
                                  Hmm I will try..
                                  Where do you learn all these commands?? πŸ˜„ It feels like I'm missing some information source(exept from this forum).
                                  BTW won't there be a conflict of axes if one for ex. have a face rotated 45 degrees?
                                    No.
                                    The problem arises if you try to project a p1 onto a face with a plane that is square to the x-axis or flat to it, as that p1 is then back on p0 and the vector can't have a zero length!
                                    • jolranJ Offline
                                      jolran
                                      That I can understand. Alright, I will have a go at it. I'm not sure a fully grasp this 😳
                                      This is more and more your plugin, it's starting to be too complicated for me. My level is more icons and stuff.
                                      Maybe one day I can contribute more.
                                      Thanks for your invaluable help TIG πŸ‘
                                      • K Offline
                                        kyyu
                                        @jolran said:
                                        Hmm I will try..
                                        You have to learn the ruby language itself. I'm lacking in this area, too.
                                        • jolranJ Offline
                                          jolran
                                          Yeah, you are right. Working on that.
                                          Good news is the code seams to be working for sorting irregular faces and hatching.
                                                p1=pt.clone
                                                p1.x=p1.x+1 # X value = x axis needs to be replaced if using another axis
                                                ve=pt.vector_to(p1)
                                                bb=face.bounds
                                                di
                                          So something like this does not do the trick yet. Will work on it..
                                           p1.each {|e|e.z+1 if face.normal.z.abs==1
                                                e.x+1 if face.normal.x.abs==1
                                                e.y+1 if face.normal.y.abs==1}
                                            Read this and try to understand...
                                            p1=p0.clone
                                            if face.normal.x.abs>0.9999
                                              p1.y=p1.y+1
                                            else
                                              p1.x=p1.x+1
                                            end#if
                                            ve=p0.vector_to(p1)
                                            ### etc
                                            This should always result in a 've'ctor with a non=zero length.
                                            To test it set up a cube and test add temporary 'puts' into the code after ve=
                                            puts face.normal puts ve.length πŸ€“
                                            • 6
                                            • 7
                                            • 17
                                            • 18
                                            • 5 / 18
