    Merge Items?
    4 Posts 4 Posters 293 Views 4 Watching
      mattols
      I have two cubes 'touching' together.
      I want erase the lines between them and merge them into a unique object.
      I can I select them and do it?
      please help me.
      • sdmitchS Offline
        sdmitch
        please help me.
        If faces that are touching are the same size and shape and are not offset then erasing the lines where the cubes touch will create a single object. If they are different in size and/or shape then they will have to be made into a group or component in order to have a single object.
        http://sdmitch.blogspot.com/
          If they are solids then you can quickly merge them with Solid Tools in SU8.
            I moved this the Developers' Forum...
            Thomthom is quite right - in v8 there are lots of new tools to perform boolean operations on two solids, and tools to make them solids beforehand [if possible]...Capture.PNG
