    Subdivide plugin? Can't find it!
    5 Posts 4 Posters 902 Views 4 Watching
    • EscapeArtistE
      EscapeArtist
      I'm not referring to SDS2 or anything that subdivides into tris. There was a plugin that I used a lot that subdivided a surface into random portions and by repeating it on a surface over and over you could get a surface suitable for Greebles or whatever. I can't remember what it is called or if it was feature of another plugin. I thought it might have been part of citygen, but I can't citygen to work to find out.
      Anyone remember or use this still? It's driving me nuts trying to find it.
      • HieruH
        Hieru
        Are you thinking of TIG's triangulate faces plugins?
        http://forums.sketchucation.com/viewtopic.php?t=20347
        http://forums.sketchucation.com/viewtopic.php?t=23638
        www.davidhier.co.uk
        • tademaT
          tadema
          Hello Jeff, I'm sure its the protrude plugin you are after.
          John
          • EscapeArtistE
            EscapeArtist
            David, those are handy but not quite.
            John, you nailed it. The protrude dialog has the "Divide Rectangles" feature I was looking for. Thanks!
            • majidM
              majid
              I am seeking a plugin that for a while I was using it to make natural stones. I have forgotten the name but when it was applied to a say cube, the result was a subdivided and noisy pull-pushed , stone-like volume. something just like a natural stone. does anyone knows its name?
              Ps: I found it : http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=54833%26amp;p=497875%26amp;hilit=noise#p497875
