    Iterator problem
    16 Posts 5 Posters 1.1k Views 5 Watching
      spireup
      I would like to use the iterator idea in ruby for my own classes but am struggling.
      Heres an example thats not working
      if Widget.each = 0
        then puts "nuo"
        else
          for myWidget in Widget.each
            puts myWidget.xPos
      Any thoughts?
      thanks
      Paul
        Paul
        Your syntax seems to be shot to pieces...
        What does 'Widget.each' generate ?? It needs a 'result' to work on like in the 'else' part!
        An 'if test' uses '==' not '='... UNLESS you are testing to see if something that is set is then =0 and then it returns true ??
        You don't need 'then' in your if's...
        You seem to be mixing up 'if' and 'each' strangely... can you please explain in 'words' what you want to do and what each 'class/method' does... otherwise we are struggling πŸ˜’
        • Chris FullmerC Offline
          if Widget.length == 0
            puts "nuo"
            else
              Widget.each do |myWidget|
                puts myWidget.xPos
          I think this is what you're getting at, translated to ruby syntax, best as I can tell.
          All my Plugins I've written
            Jim
            But what property of the Widget is to be iterated?
            Very generically:
            class Container
              def each
                if block_given?
                  while(prop = next_property() != nil)
                    yield(prop) # yield what?
            c = Container.new
            c.each{|t| puts t}
            But your class may use a built-in collection (like an Array) to store data internally, in which ase you can use the each method in your custom each method:
            class Container
              include Enumerable
              def initialize
                @data_ = []
              def each
                if block_given?
                  @data_.each{ |d|  yield(d) }
            c = Container.new
            c.each{|t| puts t}
            Once you define the each method, you can include Enumerable and get a bunch more iterators:
            Enumerable.instance_methods ["find_all", "sort_by", "collect", "include?", "detect", "max", "sort", "partition", "any?", "to_a", "reject", "zip", "find", "min", "member?", "entries", "inject", "all?", "select", "each_with_index", "grep", "map"]
            • Dan RathbunD Offline
              Dan Rathbun
              Why not just define Widget to be a subclass of some standard class that has module Enumerable mixed-in?
              class Widget < Array
                # define custom methods here
              end # class
              Widget will inherit an each iterator method from it's superclass, as well as an each_with_index method from Enumerable. (..and many other iterator methods, such as all, any, collect, etc.)
              I'm not here much anymore.
                spireup
                @tig said:
                Paul
                Yes Im miles off!
                What I want to do in words: I have a class called Widget. If there are no Widgets then I want to run a block of code. If there are some Widgets then I want to iterate through them and run a block of code using some or all of each Widgets properties.
                  What are these Widget 'properties' ?
                    spireup
                    Hmmm. the .length didnt work. Came back undefined method. At the moment Widget is a bespoke class not like what the guys have suggested below.
                      spireup
                      Thanks TIG. Firstly my problem relates to all my classes rather than just one. Ive put Widget is as an example of my problem.
                      However most classes will have x,y,z position info as properties plus a bunch of meta info properties such as :windZone, :snowZone, :saltZone, :quakeZone.
                      Im mulling Dan and Jims suggestion of a subclass but Im not sure how these proeprties would fit into say a hash or an array. I read somewhere by ?thomthom that hashes perform better so Im going to try and work with them once I bend my head around them.
                        class Widget
                          attr_accessor( ;x, ;y, ;z, ;length )###etc
                          ### rest of methods
                        will return the instance variables @x, @length etc that will get set inside other class methods etc, in the form Widget.x or Widget.length etc......
                          Dan Rathbun
                          You need two classes:
                          class WidgetSet < Array
                          end # class
                          MyWidgets = WidgetSet.new()
                          class Widget
                            def initialize(*args)
                              # args array can be used here to init
                              # attribute values @x, @y, etc.
                              MyWidgets < self # append this instance to set
                          end #class
                          EDIT: you don't actually needs a custom Array subclass, you could do:
                          MyWidgets = []
                          and just use a normal Array if you don't need to add any custom methods to your Widget collection.
                            Dan Rathbun
                            BTW.. if you want your Widgets to persist across sessions.. perhaps Components and attached Attribute Dictionary might be a better solution. (You cannot add custom object class instances to a model's entities.)
                              spireup
                              Ok thats an important point. Yes I would like my widgets to persist. But Im wanting to do a lot of analytics on the components so maybe Im going to need to use attribute dictionaries for working within sketchup but hash based classes for doing the analytics.
                              I guess Im keen to learn each of the methods that has been suggested so I can choose the right one as I get more familiar with them and the project.
                              Could you show me some example code of your earlier suggestion but using Hash as a superclass. Im interested in seeing how the initialize method would look to have say 4 properties xPos, yPos, zPos , type?
                                spireup
                                MyWidgets = []
                                Yes youre right Dan Ive been reading about Containers at http://www.ruby-doc.org/docs/ProgrammingRuby/ and I see they use two classes Song and SongList in their example.
                                  spireup
                                  @tig said:
                                  class Widget
                                  >   ### rest of methods
                                  > end
                                  Thanks TIG. Yes Ive figured out that attr_accessor and was successfully accessing my Classes properties but not in the context of the suggestions of using Arrays or Hashes as super classes.
                                  Dan illustrates this
                                  > end # class
                                  > class Widget
                                  >   end
                                  > end #class
                                  Now Im just trying to get the syntax right for those inner args arrays. eg(not working)
                                  end # class
                                  class Widget < Hash
                                    attr_accessor ;arg1, ;xPos, ;yPos, ;zPos, ;height, ;width, ;type
                                    def initialize(arg1, xPos, yPos, zPos, height, width, type)
                                      Hash.new["arg1", arg1, "xPos",xPos,"yPos",yPos,"height", height, "width", width,"type", type]
                                      @arg1 = arg1  ##etc for each arg
                                      MyWidgets < self
                                    Dan Rathbun
                                    > end # class
                                    > class Widget < Hash
                                    >     MyWidgets < self
                                    >   end
                                    It does you no good to construct an object without a reference to it (the line with Hash.new).
                                    If you want to use a Hash, then use one for your Widgets. They need not be a custom subclass, unless you need custom methods. Hashes dont need attributes (instance refs,) because they use key / value pairs, instead.
                                    my_widget_1 = {
                                      'xPos' => 3.4,
                                      'yPos' => 1.0,
                                      'zPos' => 2.3,
                                      'height' => 6.784,
                                      'width' => 4.0,
                                      'type' => "some_type"
                                    There is another thread on how to save and retrieve hashes into/from an Attribute dictionary.
                                    see: http://forums.sketchucation.com/viewtopic.php?f=180&t=30066
                                    Arguments: *list_name compacts an argument list into a local array referenced by list_name
                                    Within the method, you can access array elements using the [] method.
                                    def some_method(*args)
                                      @xPos =( args.size>0 ? args[0] ; 0.0 )
                                      @yPos =( args.size>1 ? args[1] ; 0.0 )
                                      # etc.
                                    If you use 5 arguments, but a call gives more than 5, the addtional arguments will be still be stored in the local array, and no ArgumentError, will be raised.
                                    I suggest you visit the Code Snippet index:
                                    http://forums.sketchucation.com/viewtopic.php?f=180&t=28846&p=323876#p322175
