    Using Vray version 01.05.30 with SU 8.0
    4 Posts 2 Posters 482 Views 2 Watching
    • J
      Jorgensen
      Because of the larger UI window, and not beeing able to render textures as environment (and beeing a kind of oldfasioned?) , I'm stuck at Vray version 01.05.30.
      I have updated to Sketchup 8.0, but my old Vray version, automatic installs in version 7.0 😞
      Does anyone know if its possible to install it to version 8.0 ?
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • thomthomT
        You mean Micas grass trick?
        Been a while since I installed that version, but it does ask you where to install, does it not?
        • J
          Jorgensen
          Hi Thomthom
          Yes, it's might be a Micas trick, but I can't find the link anymore.
          It works fine in version 01.05.30, but if I do exactly the same in the newer versions it looks very strange. Do you know if I'm doing something wrong, and it acualy works in the newer versions ? that would be nice. I have attached the texture I use, so you can se if we are referring to the same method.
          When installing it does not ask for a folder, just automatic installs it in sketchup version 7. Might be because I heve both 7 and 8 installed.
          • thomthomT
            No - I've not got it to work. Still bugged.
            hmm.... maybe... can't remember any more...
