    Drafting line tool
    5 Posts 4 Posters 446 Views 4 Watching
    • M
      mwm5053
      Is there a line tool**(plugin)**that will draw dashed lines, heavy lines and such like in draft or CAD program.
      Thanks Walt
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • D
        d12dozr
        TIG's 2D Tools
        There are others as well, if you search around a bit
        http://goo.gl/f7ooYh
        • J
          Jim
          Thanks Walt
          2d tools does what you ask, but probably not in the way you are thinking. 2d tools draws thick lines and dashed lines as 3 geometry because SketchUp only has 2 line types - Edges and ConstructionLines. There are several different Constrction Line styles, but none can have thickness. You can turn on Profiles from the Styles dialog, but Profiles are only eye candy and do not (can not) change the line thickness.
            There's the Dashed Line plugin from smustard.com. It works quite well.
            • M
              mwm5053
              Thanks I'll give those a try. Just needed to show some hidden lines in floor plan.
              2011 iMac
              V2 Twilight
