    Auto-Save Plugin?
    2 Posts 2 Posters 442 Views 2 Watching
    • P Offline
      pscarch
      Jim,
      I have little programming knowledge, and am not quiet sure of where to post requests on the forum. I need a plugin that can auto save-as, so that there are previous versions of a model. It would be beneficial to have customization auto save time intervals, as well as customize the extension to the name (ie. model_1, model_2 etc.). This would be highly useful for me as I often am requested to go back to a stage in the model which I have saved over (as a result I do this process manually). If you could point me in the right direction it would be much appreciated πŸ˜„.
        There is the Auto-Save feature built-in to Sketchup - Menu Window > Preferences Capture.PNG
        There's also my 'Archiver' tool, that saves a new snapshot copy of the SKP into an Archive folder with the model, whenever you run it - it appears on the File menu so you can shortcut key to it and quickly save a version as you go by a simple key press... Letting you save copies at crucial changes etc as the copies are date/time stamped in order...
