    Solids Penetration Check plugin
    5 Posts 3 Posters 404 Views 3 Watching
    • voljankoV Offline
      voljanko
      Hello.
      I would like to have (make) a plugin that checks all the solids with other solids if they intersect.
      The result of the intersection should be a solid (to avoid positive results if solids only touch each other.
      I have found only the method Group.intersect suitable to do this.
      But the problem is that this method is not only checking the intersection but also remove the two solids and do a new
      solid (or face if two solids only touch each other).
      I would like to know if there is a plugin that already do this.
      If not, I would appreciate any idea how to deal with this problem.
      Thanks for help and have a nice day.
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        I don't know of any script that does this...
        What you could do is copy the two groups you are testing into a new temporary group.
        tgroup=model.active_entities.add_group()
        Get the groups' definitions
        def1=group1.entities.parent
        and
        def2=group2.entities.parent
        Add these to the tgroup
        tgroup1=tgroup.entities.add_instance(def1, group1.transformation)
        and
        tgroup2=tgroup.entities.add_instance(def2, group2.transformation)
        Now do your boolean code on tgroup1 and tgroup2.
        Any resulting ' igroup' is left inside tgroup.entities
        If there is anything there erase group1 and group2 and explode tgroup so the ' igroup' is left OTHERWISE leave group1 and group2 alone ??
        • voljankoV Offline
          voljanko
          Thank you for the very useful suggestion.
          I have almost finished the plugin,but (you can guess) there is a problem.
          The transformations of solids are local within the group,but I need it global,because I want to check
          also the intersections between the solids from different groups.
          So,how to get the global transformation of every solid?
          I hope there is an easiest way than store and multiply every transformations from parent-groups.
            @voljanko said:
            Here it is,my first public plugin πŸ˜„
            In some cases the intersections between solids can be considered as mistakes.
            Just select some solids and click the Intersection Inspector from the Plugins menu.
            The intersections between solids will be highlighted (selected).
            To see the hiden intersections,use the x-ray option.
            What do you think about it?
            Can you please make a new post with this? And tag the title with [Plugin] like the rest of the plugins here at the forum.
            Otherwise it's impossible to find it - it's buried far down into this thread.
            • voljankoV Offline
              voljanko
              Just select some SOLIDS and click the Solids Penetration Check from the Tools menu.
              The intersections between solids will be highlighted (selected) and colored red.
