Distributed Rendering Spawner VIA INTERNET
renderpluginsextensions
6 Posts 3 Posters 2.5k Views 3 Watching
    Davi Melo
    Does anybody know if it's possible to use Distributed Rendering Spawner via INTERNET?
    Davi Melo
    http://dm2projetos.blogspot.com/
    SKP8 - Vray 1.48
    WIN 7 ULTIMATE 64x
    INTEL CORE 2 QUAD 2.33GHz
    RAM 8GB
    NVIDIA GEFORCE 9600 GT
      dkendig
      As long as you can communicate with the spawner, it will work. I've used DR over a VPN without any trouble. Just be aware that the scene assets need to be transferred to the spawners, and an internet connection is nothing compared to a 1gb/s local network. There's also tons of little problems that could pop up that would prevent communication with the spawners from working properly. So will it work? Sure! Is anyone at Chaos Group going to help you if you have trouble with it? No, it's not something that is supported by their support team.
      Devin Kendig
      Developer
      • N Offline
        narch4
        dkendig,
        is it a trouble for you to explane witch VPN do you use and how.
        I am having problem to see a PC at my work place from one at home.
        My pc at work is a part of local network.
        I hope that your explanation can help me.
          dkendig
          I've used a couple VPN clients, it's all the same though. As long as we can communicate with the DR Spawner, it doesn't matter how you're connected. Be sure to enter the IP address of the machine that is running the DR Spawner though, not the computer name. It's possible to have DNS issues that can cause trouble resolving host names, so if you manually specify the IP address of the machine, you'll have a better success rate.
          Devin Kendig
          Developer
          • N Offline
            narch4
            Oh yes, tnx.
            I will try adding IP manually.
            I was just afraid that I might have some issue because all pc-s at work are behind a rooter (nat) and have a local ip's.
            I can connect to one via T..amVi..er but Vray can't find IP.
            I will try adding one manually and get back with the result.
              dkendig
              NAT is not an issue once you're connected to a VPN, because you're connected to the internal network that lives behind the NAT at that point (unless you have some sort of special setup)
              Devin Kendig
              Developer
