    [Code] Printing color range as grid for preprint checking
    11 Posts 6 Posters 1.4k Views 6 Watching
    • U Offline
      unearthed
      I'm not into rendering yet, just simple output, but when I choose colors in the model I want to see how they'll look before I print - (I usually have a printed test card for this (see example). In the example included (from vectorworks) it can be useful to have a color name or number or RGB etc. Is there a way in Sketchup to at least print out a current color grid, with an option for color info would be great. I've searched hi and low for this and found zilch.
      SU version:8.0.4811
      OS win 7
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
        Not entirely clear...
        This is what I think you mean... you want a tool that makes a grid of squares, each with one of the SKP's materials added and some text showing it's details shown [Name, description, RGBA, texture].
        I suppose ideally this would be a group that's on it's own layer that is also only shown on its own scene-tab that is excluded from animations etc, and the view set to 'plan'...
        Correct me if I'm wrong...
          Copy+paste this code into a file called colorswatch.rb in the Plugins folder.
          Restart Skecthup and type TIG.colorswatch into the Ruby Console... to make a colorswatch group/scene/layer etc.
          module TIG
           def self.colorswatch()
            model=Sketchup.active_model
            ss=model.selection
            defs=model.definitions
            ents=model.entities
            layers=model.layers
            pages=model.pages
            mats=model.materials
            names=[]
            mats.each{|mat|names << mat.name}
            names.sort!
            num=names.length
            return nil if num==0
            model.start_operation("colorswatch")
            ### erase previous ones
            gps=[]
            defs.each{|d|gps << d.instances if d.group?}
            gps.flatten!
            gps.each{|g|g.erase! if g.valid? and g.name=="colorswatch"}
            ### make new one
            gp=ents.add_group()
            gp.name="colorswatch"
            gents=gp.entities
            ### make tile
            tile=gents.add_group()
            tents=tile.entities
            face=tents.add_face([0,0,0],[200,0,0],[200,200,0],[0,200,0])
            face.reverse!
            trx=Geom;;Transformation.translation([400,0,0])
            try=Geom;;Transformation.translation([0,-400,0])
            dim=Math.sqrt(num).round
            step=dim
            (num).times{|i|
              mat=mats[names[i]]
          	tile.material=mat
          	txt=names[i]
          	rgb="RGB = "+mat.color.red.to_s+", "+mat.color.green.to_s+", "+mat.color.blue.to_s+"\nAlpha = "+mat.alpha.to_s
          	txt=txt+"\n"+rgb
          	if tex=mat.texture
          	  txt=txt+"\n"+"Texture = "+tex.filename
          	end#if
          	gents.add_text(txt, tile.bounds.min.offset([0,-20,0]))
          	tile=tile.copy
          	tile.transform!(trx)
          	if i==dim-1
          	  tile.transform!(try)
                step.times{tile.transform!(trx.inverse)}
          	  dim=dim*2
              end#if
          	if i==num-1
          	  txt="[<Default>]"
          	end#if
            ### put on layer
            layer=layers.add("colorswatch")
            layer.page_behavior=LAYER_IS_HIDDEN_ON_NEW_PAGES
            pages.each{|p|p.set_visibility(layer,false)}
            gp.layer=layer
            ### make scene-tab
            pnames=[]
            pages.each{|p|pnames << p.name}
            if not pnames.include?("colorswatch")
              pages.add("colorswatch")
            end#if
            page=nil
            pages.each{|p|page=p if p.name=="colorswatch"}
            pages.selected_page=page
            layers.to_a[1..-1].each{|la|page.set_visibility(la,false)}
            pages.selected_page.set_visibility(layer,true)
            ### zoom extents
            eye=gp.bounds.center.clone
            eye.z=eye.z+1
            tar=gp.bounds.center.clone
            up=[0,1,0]
            model.active_view.camera.perspective=false
            model.active_view.camera.set(eye,tar,up)
            Sketchup.send_action("viewTop;")
            model.active_view.zoom_extents
            Sketchup.send_action("viewZoomExtents;")
            page.update(127)
            model.commit_operation
          It's not perfect as I threw it together quickly from other code... but will form the basis of what it is I think you want... πŸ€“
            sergey2402
            Dear TIG. I beg your permission to use your script as a plugin colorswatch.rb
            colorswatch.rb
            • U Offline
              unearthed
              Hi TIG, that's great, was very surprised you actually coded an answer.
              I had to meddle with the arrangement to print it but it's really useful.
              I hadn't thought as far as having it on its own scene tab, in a group etc, but
              yes that works well. I'll try and meddle with the text part now to select
              just the material name or RGB etc.
              cheers
              Nigel
              colourswatch from TIG's .rb
                This should be marked with [code] - or better yet - made into a new thread with the .rb file for download.
                  Moved to 'developers' and [code] added...
                  • KrisidiousK Offline
                    Krisidious
                    AWESOME!
                    By: Kristoff Rand
                    • atelierpaarA Offline
                      atelierpaar
                      Hello Tig,
                      thanks for your "colorswatch" script.
                      I checked it out and it does pretty much what I had in mind.
                      Unfortunately the script seem to grab just the colors that are already in the Model.
                      It would be of great help, if one could choose a specific library / Folder like for Instance "Colors" or "named colors" or what ever Library there might be.
                      Do you think this would be possible ?
                      Uli
                        Unfortunately there is scant access to SKM files through the API...
                        Although my SKM-Tools do add some functions which could allow this...
                        It could get convoluted, since it would have to load all of the external SKM materials into the current model to be able to display them anyway πŸ˜•
                          atelierpaar
                          Hello Tig,
                          thanks for looking into it.
                          Just the SU Material file "colors" contains 310 Colors.
                          Each Color has to be selected and applied to some surface in order to get the color into the model.
                          It`s the tedious manual work that discouraged to make a color guide. πŸ‘Š
                          Is there perhaps a another way of mass-loading materials into a model ?
                          Uli
